Posts: 51 |
I'm running 17" Enkei RS6's with 215/45z/17 tires on my SVT and I get a little rubbing with 4 people in the car. What is the best way to remedy this? Stiffer Sway bar, thus less body roll? Spacers (what size)? Other fixes? Thanks for the advice.
2000 SVT Tour Silver Frost/Midnight Blue #1683 of 2150
Posts: 81 |
Posts: 1,507 |
Originally posted by SVTee: Throw one person out. or tell your friends to go on a diet :p
-- Mike (Moe)Lester -- 98.5 SVT #5486 moesvt@comcast.netGet your a$$ on IM and stop wasting bandwidth!!!!!!
Posts: 240 |
Originally posted by rastamahal: I'm running 17" Enkei RS6's with 215/45z/17 tires on my SVT and I get a little rubbing with 4 people in the car. What is the best way to remedy this? Stiffer Sway bar, thus less body roll? Spacers (what size)? Other fixes? Thanks for the advice. get wheels that fit correctly. :p but in all seriousness, we need to know what width and offset your wheels are in order for us to help. where are you rubbing? what car? what suspension?
Please: put something meaningful in your post subject! NOT "please readme!". -------------------- "your" is possessive, "you're" is the conjunction that is short for "you are", "there" is for "the dictionary is over THERE", "their" is the possessive one, and "they're" is a conjunction that is short for "they are". have a nice day :rolleyes: -------------------- Silver Frost non-E1 SVT/Contour see my registry/profile: http://contour.org/carprofile/carprofile.cgi?a=display&uid=00004623
Posts: 168 |
What is the best way to remedy this? Stiffer Sway bar, thus less body roll? Spacers (what size)? Other fixes? Under what conditions does it rub? When both wheels go up, or during cornering? What do they rub on? The wheel well liners, or the strut, or the fender lip? I would be VERY hesitant to try to fix a rubbing problem by changing a sway bar. Sway bars are for changing cornering balance, not for keeping aftermarket components from fighting over real estate. My snow tires (215-55-16 on E1 wheels) rubbed the back of the wheel liner, just in front of the muffler, because the rolling radius was larger than stock. That was easy to fix - I just cut the liner with a tin snips. -Kurt
-Kurt
"I'm a little sceptical of that internet thing. After all, what's it got besides information?" -DB, 1/97
Posts: 51 |
but in all seriousness, we need to know what width and offset your wheels are in order for us to help. where are you rubbing? what car? what suspension? Thanks guys... the wheels are Enkei RS6's 17x7 (offset 38mm), with Kumho 215-45z-17 tires. I mostly rub on the passenger rear tire, not sure exactly what it is rubbing on. Happens on cornering and when both rear go up. My car is a 2000 Contour SVT on stock suspension. Thanks for the advice.
Posts: 1,444 |
your offset is too low. 7 inch needs a minimum of 40 to not rub. buts its too late for that. gotta find out where the tire rubs, what part of the fender area.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 1,444 |
munson, u should've gotten 205/55 for snows. thats what i got. narrower tires in the winter is better to cut into the snow better.
AIM:omegazodiac
Posts: 5,805 |
Roll the fenders and mod the liners...
Posts: 168 |
munson, u should've gotten 205/55 for snows Yeah, tell me about it :rolleyes: . Shoulda, woulda, coulda.... -Kurt
-Kurt
