Posts: 73 |
A tire which is more narrow is better in the snow. Ask any tire expert. The wider the tire, the more resistance and the more snow a tire has to "plow" through. My Goodyear Ultra Grip Ice snow tires size 205/55-16 are WAY narrower than regular 205/55-16's.
-Rob
1999 SE Sport, Medium Steel Blue (CEG member since 2/98) SVT Dual Exhaust w/ Magnaflow res. and 3 1/2" SS Tips, E0 SVT Rims w/ Kumho 225/50ZR-16's, Superchip, SVT KKM, SVT Side Skirts, SVT front and rear bumpers, BNM white-faced gauges w/ blue glow, Carbon Fiber Shift Knob, no intake resonator, BAT Big Brake Kit C, Roger R dead pedal *DEFINITE future mods, by 7/02* wider rims, Y-pipe, revised exhaust, SVT TB, SVT Upper Intake w/ powder coating (GO BNM!)
Posts: 3,223 |
Originally posted by svtavino: The rim is a 16. I think it is a 6.5 width but i am not positive. It is a little narrow for 225 but it is still fine. It seems all the posts I have read said it is fine with no rubbing. Nope they are 7" if they are the stcokers! -Andy
Posts: 1,051 |
SVT E0 and E1 rims are 16X6.5", according to SVT.
P.M. Summer -- simul justus et peccator
2000 SVTour Silver Frost 374/2150 -- #9669 of 11445 total run Blaupunkt Heidelberg with A08 Changer and RC-09 remote, Boston Acoustics, K&N, Mobil 1 and Cobra R Mobil 1 "Factory Fill" plate, 35% metallicized tint, high beams in the lows, Bill Jenkins' "off color" floor mats, and custom "koozie" cupholder (pics soon!) 96 Sable ZZZ (wife's)
Historic Ownership: 42 Dodge Powerwagon Munitions Carrier, 59 Morris Minor, 64 TBird, 69 BMW 2002 Blue Dot, 72 German Ford Mk I Capri V6, 76 Honda Accord, 82 VW Scirocco, 88 VW Jetta, 91 Ford Escort GT, 98 Countour SE Sport V6 ATX
Cars I want: Lotus Elan S2, Austin Healy Sprite Mk I, my old BMW 2002 back.
If you think this sig is long, you oughta see my undergraduate transcripts!
Posts: 3,223 |
I've measured and put on a tire machine the measuring tool says 7"
-Andy
Posts: 96 |
So if the wheel width is 7" like you say it is, it should fit with no problem, right?
One more thing...I DO know my physics and know that the wider the tire, the worse it is in snow...but is 225 too wide?? I noticed today at school that the Grand Am GTs come with 225/50/16s on them, and I see a lot of those here in Michigan, so they can't be too bad on those anyway...opinions please!
99 Black SE Sport ATX Running on E1 SVT rims with Dunlop rubber Pioneer DEH-P3100 CD receiver (2 channels of the amp blown, officially declared dead) Pioneer DEH-P440 CD receiver Pioneer TS-6865 6x8's in the front Pioneer TS-6867 6x8's in the rear Pioneer TS-WX121 Sub with a Pioneer GM352 amp feeding it
Posts: 1,051 |
Originally posted by Andy W.: I've measured and put on a tire machine the measuring tool says 7"
-Andy Did you measure inside to inside or outside to outside? Ford still says 406x165mm (16x6.5") in my E0 and E1 brochures, in my handbook, and on the SVT site. It would be neat if you were right.
Posts: 73 |
I'm sure they wouldn't be that bad if you had all-season's or snow tires...you'll be able to get around in the snow ok, but I wouldn't expect excellent traction, say, up a hill in just light or moderate snow. Alot if places, like Tirerack, recommend a "winter package" especially for wider tire equipped cars which see frequent winter duty. The only way you'll know for sure is to try it out and see what kind of traction you have, although it's getting a little too late for snow as the month moves on. HTH.
-Rob
Posts: 3,223 |
E1 Rims have a lip. Tire balancing machines base the width on the placing a tool just inside that lip on either side of the rim. E1's measure 7" and that is how all tire balancing machines work so I would imagine that how tire compies would to! The math for the balancing would be off otherwise!
225 will fit just fine!
I promise!
-Andy
Posts: 96 |
Originally posted by svtavino: Just got those tires for my wifes car. They are very nice, quiet and seemed to do well in the snow. If you are worried about the snow go for 205/55/16. I have this size on my car in the dunlop 5000s. This is the size that originally came on the SVT. They don't look overly small. I think I will be going with the 225/50/16 in either the 5000s again or the KDWS both are a little more sport oriented and still all season. The A2s are a good deal and excellent tire. Are your A2s the 225/50/16 size on the Mystique or a different size?
Posts: 96 |
Ok, how about BFGoodrich Comp T/A VR4s in 215/50/16 size?
They're more expensive than the SP Sport A2s, but are the right size. Anyone have em? How do they perform? In the snow?
