Posts: 68 |
I am wanting to get some 17s. I was wondering how wide the rims should be and what size tire i should be looking for. Thanks for the help.
Tony
1999 Contour SE 2.0L VCT Mods: *BFGoodrich P195/65R14 *Pioneer 3100 Cd player *Pioneer 6'x8' 3-ways *2 12' Super Blue Subs *Pyramid 400 Watt Amp *Yellow Fog Lights *Magnaflow Exhaust #14822
Posts: 1,732 |
IIRC, probably best to stick with the a 17x7 if you plan to lower the car. 215-45-17 is the optimal tire size - which is what I have. Gator VR4 was running 17x7s with 205s (?) and he disliked it. Good luck!
- Pete - 00 SVT SF/MB - 1522/2150 - DOB 1/12/00 ------------------------------ 92% says your group-NOT HOT 85% says your either wrong or BLIND Blackhawk Down did NOT suck you know who you are.....
Posts: 4,319 |
AMEN! I ran 205/40-17 Yokohama Paradas and absolutley hated em. I liked the tire itself, but the 40 series ride was way too harsh. Plus they do a very poor job of filling the wheel well....
1991 GVR4 Lots of mods done.
Posts: 68 |
Alright that sounds good. I just wanna make sure. Any rubbing, grinding, or whatever else could go wrong in the wheel well happen with the wider tire? Thanks for the help
Tony
Posts: 77 |
I plan on buying new 17" wheels in April-May. I am sticking to the 17x7 with a 40 offset. Tires, I plan on having 225/45/17. After much research, I found this to be the best combo for looks/functionablilty on the tour.
1998 Silver Frost Contour SVT #1031/6535 ~a few mods~
Posts: 1,444 |
i found a wheel i like. 17x7.5 42 offset, will this be a problem. i want to run 225/45 or if i have to 215/45. i think the lowest (safest) offset to go to is 40. am i remembering this right.
can i run this w/ stock suspension. i plan on eventually upgrading to coilovers w/ konis, but can i get the wheels first or should i wait.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 81 |
I'm running 17x7.5 with 215-45s and a 45mm offset. Plenty of clearance inside and out.
You should be able to run 225-40 with 42mm offset.
Any clearance trouble might be on the outside at the fender lips.
I believe 225-45s would be tto tall.
I recomend the 215-45-17 as a perfect fit. The 7.5 width and 42mm offset will give the 215's a much wider look.
Posts: 1,444 |
AIM:omegazodiac
