Posts: 10 |
OK, one last try at this because I just can't make up my mind Replacing my KDW 215/50/16s that came stock on my 99 green SVT and I've found out a couple things. One, you can't buy that size tire at a decent price, even at costco they are 700-800 for a set. That's no problem, of course, since they do have the 225/50/16s at about 500 a set in both the KDW and the Potenza 730 I like the KDWs I have on the car now, they stick very nicely, though they are loud at low speeds and now vibrate a bit at higher speeds.
But in tire forums the prevailing thought on the 730s is they get very loud after several thousand miles.
Has anyone had this experience with the 730s. I really don't mind some noise if it isn't overwhelming.
Posts: 1,217 |
driven with both on my '99, your splitting hairs with this one IMHO. Either would be a good performer, I'd go for COST, all else being equal.
Mark
Posts: 1,861 |
Look at the KDWS instead of the KDW. It is much quieter. It is an unusual tire in that it is an all season ultra high performance tire. $115.00 each at tire rack in 225/50R16.
Jim Johnson 98 SVT
Posts: 356 |
I think you should check tire rack or try to pm luke from tirerack. I got a set of potenza s-03's for something like 640-650 to my door. So you should be able to find either of the tires you are looking for a lot cheaper. Oh and by the way s-o3's kick a$$!!
99' tropic green SVT 2558/2760 born on 08/06/99 KKM, resonator removed, B&M short throw, SHO shop y-pipe w/cat, Pioneer deck, Boston Accoustics 10" rallys, MTX thunder amp
Posts: 1,444 |
and the kdw's (not kdws) were under 100buck each a few months back. i think they r 115 now (give or take a little) and in 215/50/16. a set should still be under 500.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 351 |
I love my RE730s, looks like I will get about 30k miles out of them.
98 Contour LX V6 Mtx
Posts: 705 |
Potenza S-03 Pole Positions
Ryan Toreador Red 1998 SVT #2843
"Performance in the hands of few"
Posts: 463 |
I think the S-03's are on sale right now on tirerack.
Posts: 2,657 |
What size is everyone running on the S03's? Any lowered suspensions? Any rubbing? I want these tires but they only have 215/55 or 225/45 in 16" sizes.
Posts: 463 |
I was looking at the 215/45/17" S03's at $156 ea.
