Posts: 134 |
would like to know what is the largest tire i can run with 18s on wy stock 98 svt
Posts: 3,331 |
99' SVT 86' Toyota Pickup Beater - Tha Daily Driver
Posts: 134 |
would u also know what would be a good offset i am getting the QT alloy S-13 and would only like to buy one set and not return them
Posts: 1,090 |
40 or 42mm, depending on the width of the wheel.
Posts: 134 |
they are 7.5" wide so is it 40 or 42 and thanks in advance
Posts: 1,090 |
the 42 will fit better, less chance of rubbing on the fenderlip.
Posts: 1,444 |
don't u think u need a stiffer suspension to avoid "bouncing" into the tire when going over a bump or something. i want 18s but thought i should wait til i do the suspension.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 4,585 |
hmouta,
It may not look as cool with big wheel well gaps and 18" rims, but you do not have to do both.
Posts: 1,090 |
Originally posted by hmouta: don't u think u need a stiffer suspension to avoid "bouncing" into the tire when going over a bump or something. i want 18s but thought i should wait til i do the suspension. here's my car with 18's before I lowered it. keep in mind this picture is almost four years old now, and my car looks much better lowered with the 18's than it did at stock height with 18's.
Posts: 1,428 |
Wow, talk about 4x4ing! Dion, I've always liked your car, you must have been one of the first on 18's huh? I remember your car from way back when I was looking at buying mine!
