I got 235/40/17s on my tour now with some slight rubbing on the outside of the wheel when I have four people in the car. If I were to put on the BAT Euro Kit am I going to rub with less people, will it be more severe, or the same as it is now? Thanks
Kevin
-= '98.5 SE Sport MTX =-
KKM
Dual Flo- No res.
17" Turner 10spoke
235/40/17 Kelly Charger HP +
No decals
Check your rear wheel lip where the rear bumper's top mounting bolts are. This is where my 235/40/17's rubbed. After beating the hell out of the wheelwells themselves and still rubbing, I finally noticed this area. A few minutes later with a set of good tin snips, no more rubbing. With the BAT kit, they're slightly lower, but slightly stiffer. I'd guess your rubbing would be about the same, until you trim the mounting tab that is. wink
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
Moderated by  1314_dup1
