#282572 01/09/02 02:51 AM
Bill D Offline OP
I need to make wheel spacers before I can mount my merkur 14" wheels. I think the bolt spacing is 108mm not sure if this is diameter or the size of the inscribed square?
Bill D.
ps: Merkur 14" wheel 41 mm offset, 95 Contour 47.5 mm offset for 14" Al rims.
#282573 01/09/02 03:28 AM
you are correct
Sam
1998 Contour SVT #180
1/4=14.2 @ 101.17MPH
AOL users = PhatSVT
_ _ _____________ _ _
1986 Mustang GT
12 second club
#282574 01/09/02 06:17 AM
Bill D Offline OP
Which is it diameter or square side?
Bill D.
A 1/4 spacer seems to be narrowest one I can find need about 3/16. with a 1/4" I lose the hub centering and might evenwant to install longer studs.
#282575 01/09/02 07:20 PM
The "108mm" refers to the diameter of a circle drawn through the center of each lug hole. This way, the measurement works no matter how many holes you have. Of course, on a 4-lug, you could measure corner-to-corner and get the same figure.
"Function before fashion."
'96 Contour SE
#282576 01/09/02 09:49 PM
Master P
Master P
Moderated by  1314_dup1
