Bill D Offline OP
I spoted a Merkur at the wreckers with four good wheels. I removed all the lug nuts and can not pull off the rear wheels. looks like i have to remove a big axle nut? Any ideas what size socket I will need?
Bill D.
PS: I am hoping the merkur 14" Al wheels will fit my contour.
i had an 87 XR4Ti. there is no central wheel nut to be removed. take a rubber mallet and tap the edges of the wheel. they have a tendency to get "tight" for whatever reason with the brake drums in the rear. what year is the car? only the 85's had 14" wheels. 86-89 were 15".
Aluminum wheels will rust weld themselves on to, IIRC, high iron content metals. Had it happen this year on my Girlfriend's '00 Mustang GT. Rub a light coat of grease on with your finger before installing them, but for now... WD-40 down the lug holes and a hammer dude. wink Merkurs have the same 108mm X 4 lug pattern, unless you have an SVT, they will fit. The front brakes will most likely cause interferance problems on the SVTs with most 14" wheels.
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
Yup, get a rubber mallet. Happened to me on my girlfriend's car. No matter what I did it wouldn't budge. Got the mallet and off it came with three hits. laugh
2000 SVT
Black & Blue
#205 of 2150
Kenwood Head Unit
2001 SR5 4 Runner 4x4
might be hard to do w/ a non-running car, but one thing that might work (should the mallet not do the trick) is to let the car off the jack w/ the lugnuts off and push/roll the car forward/backward. sometimes the weight of the car is enough to break loose the rusty connection....had to help a couple teenagers w/ changing a flat on their old ragged-out honda accord a while back. rim wouldn't come off at all, nobody had a hammer, etc. etc. etc. so, to avoid waking up their friends/family at midnight, i suggested the above...rolled the car forward a couple feet and *POP*! came loose. jacked it back up, swapped it out for the spare, and they were ready to go.
fwiw....
blake
02 acura RSX type S, arctic blue pearl/ebony
- OEM fogs, S2k shift knob, 35% formula one tint, injen SRI
62 chevy C10 fleetside pickup, tan
- stock I-6, 3-on-the-tree, currently immobile in my garage
former owner of:
98.5 E1 SVT #4910, silver frost
Bill D Offline OP
Here is a merkur wheel interchange chart I found. Might be of some use to others. also in 1995 what is stock steel wheel width/offset?
Bill D. http://www.merkurencyclopedia.com/Suspension/wheels.html
I have had this problem as well. If loosening and rolling or a rubber mallet don't work, hose the lug nut holes down with Blaster (buy it at Murray's or Autozone) pump the tires up as high as you dare (50-60 psi) and hit the tire (not the wheel) with a full size sledge hammer. Worked for me.
take a ride, take a shot now
Black 98.5 SVT (sold)
Silver 99 SVT (work in progress)
Bill D Offline OP
I got the wheels off. just used a dead blow hammer. hard to get a good angle but they came off. They bolt up to my fronts but i think they need to be spaced out about 1/8" for better caliper clearance.
Bill D.
ps: these are E41 backset
Moderated by  1314_dup1
