Page 2 of 2 1 2
#281916 11/25/01 03:29 AM
E
ESC Offline
E
Originally posted by Big Jim:
I used to have one bookmarked, but I lost it when my computer crashed a few months ago.
Here you go:
http://www.miata.net/garage/tirecalc.html
#281917 11/25/01 03:23 PM
Brad P... you can fit the 205/55/15 tires on your car no problem. They aren't any wider than the 205/60/15. The "205" is the width of the tire, while the "60" or "55" denotes the sidewall height, or profile.
My friend Ron has a '95 Contour SE with 205/55/15 tires on it, and the only difference is that the car sits a little lower. Nor does he have any wear problems. He's had them on the car for over 2 years now.
-Jeff
-"The Crazy Canuck!!"
-"Rice": Anything that looks faster than it really is...
My Ride! http://members.sounddomain.com/sideoftheroad
#281918 11/25/01 06:20 PM
N
NMC Offline
N
A 205/55 tire may appear to be wider than a 205/60 tire but overall it is not. The 205 part is the overall width of the tire, not the tread. The tread will vary from about 180-200 mm (for a 205 tire) in width depending on manufacturer and construction. A lower profile/higher speed rated tire can be made with a wider tread due to reinforcing of the sidewalls. When buying performance tires always look at the manufacturers specs for tread width as it can vary up to an inch for identically sized tires. After all, contact patch is everything.
96LX/24V/ATX/Midnight Red/A4 repeaters/SVT exhaust/KKM/65mm throttlebody/SVTsprings and ST200 struts/SE rockers and BAT spoiler/BAT 19mm swaybar/urethane bushings/Kenwood 7 speaker syst./E1 SVT brakes w Powerslot rotors/9005 lowbeams/885 fogs/50% tint/Michelin XM+S 130's for winter/E1's with gForces for summer...and now "New Paint!!"
87 Renault GTA convertible/2.0l/mtx/Sony sound/otherwise stock
http://members.shaw.ca/neilmc/
#281919 11/25/01 07:40 PM
Brad P Offline OP
Hay thanks for all the response. I don't want to put something on that will not work efficiantly. The Kumho's are the ECSTA Supra 712. They come in 205/55/15 but not in the 60 series. I also looked at cooper cobra XST, but not sure hoy good coopers are. But the cobra XST comes in 205/60/15. Tuff decision on what to do. frown
Aviation Electronic Tech's RULE!!
Your born you die
inbetween you work on cars
how can we be so lucky.
99'Mystique Zetec VCT ATX
"CEG" on front and back windows.
10 inch HED series Cerwin-Vega
My ther car is a 1996 4Runner
Sunfire red pearl
with Bilstein shocks, K&N air filter
and Xenon fender flairs
"There is always room for more mods"
Page 2 of 2 1 2
Moderated by  1314_dup1
