#281857 11/15/01 05:29 PM
My Tour currently has 205/60/15 on it. Can I run 205/50/15's on it?
Please no flames I dont know ANYTHING about tire size.
2002 Mitsui Lancer-Black MTX.
#281858 11/15/01 05:44 PM
APT Offline
You can. However there are effects on speedometer and odometer.
Punch in those numbers @ the Miata garage to find out exactly how off each will be. In general, it's best to keep the overall diameter/circumfrence the same when changing tire size. Like, 225/55R15 wuld be a lot closer to your stock size. However, I would not gaurantee that a 225/55R15 tire would fit on your rim on your car.
#281859 11/15/01 06:11 PM
Ok sounds like I should stick with that size. Altough I may change rims, could I run 17 inch tires and wheels on the GL?
#281860 11/16/01 12:02 AM
I heard it also affects the ABS computer to have incorrectly sized tires.
Moderated by  1314_dup1
