#281681 11/05/01 10:27 PM
ASSVT Offline OP
luke i am in need of your'e infinite tire knowledge. i will soon be needing new tires and i have narrowed it down to two.
potenza S-03's 205/50/16 or
the stock KDW's 215/50/16
i guess main question here is are the S-03's worth $28 more per tire?
i am a rather aggresive driver and live in ca
so no severe weather.
any and all insight greatly appreiciated (sp?
99' tropic green SVT
2558/2760
born on 08/06/99
KKM, resonator removed, B&M short throw, SHO shop y-pipe w/cat,
Pioneer deck, Boston Accoustics 10" rallys, MTX thunder amp
#281682 11/06/01 09:20 AM
My names not Luke but I doubt you'll mind if I chime in. I've been looking at Ultra performance tires for next dry season(Denver)and the s03's are at the top of my list. I thought I saw them in a 215 size on tire racks site but maybe not. Have you considered upsizing to a 225 in the s03s? I know they make those. laugh
#281683 11/07/01 12:27 AM
S-03's are seriously the best non drag tire you can get for serious traction, nothing is stickier, i would get them if i had money to replace them every summer (sticky read=no treadwear)
95 SE Champagne Mettalic
True Dual exhaust with X pipe and Redline mufflers
KKM Tru Rev intake
H&R Springs/KYB struts
Apex-i S-AFC
65mm Throttle Body
17" Ace Spades
4 Pt Racing Harness
Window Tint all around
New Engine @ 117k kilometers
G-Tech: 15.6 @ 91.5 MPH
"you officially kick ass"
quote from awed CEG'er after i chopped my hood and threw on scoops
RIP 98 SVT silverfrost *nov 4 2001*
#281684 11/07/01 03:23 AM
ASSVT Offline OP
thanks for the info guys!!
i now have dunlop sp 8000 225/50/16
it seems to clear no problem.
from what i have been reading S-03's are the way to go. now just need to figure out should i go with 205/50/16 or 225/50/16.
teh 225 are like $20 more eack IIRC.
oh well decisions decisions.
once again thanks for the replys
2558/2760
born on 08/06/99
#281685 11/07/01 02:14 PM
The S-03 Pole Position is the best tire money can buy !!! it is most assuredly worth the extra $28 bucks
Luke
Luke Pavlick
Sales Representative
ASE Certified Master Tech
For more info on any post
or to place an order please
call 800-428-8355 ext. 362
for on-line orders mention
my name in the previous
contact field for prompt
personal service.
www.tirerack.com
I want to die peacefully in my sleep
Like my Grandfather
Not screaming and frightened like
the passengers in his car !!!
#281686 11/07/01 05:05 PM
ASSVT Offline OP
thanks luke! might be trying to get in touch with you soon to pick up a set.
2558/2760
born on 08/06/99
#281687 11/07/01 06:11 PM
CYS Offline
Just wanted to add that you might not want the wider (225) SO3s as they seem to run wider than most other brands. I replaced 235 Pirelli Rossos with 225 SO3s and the 225 SO3s were just as wide(if not wider) as the 235 Pirellis. The SO3s are a great tire and I think you will definitely like them, just wanted to warn you about the width - which may cause you to have serious rubbing issues.
#281688 11/08/01 04:03 AM
i am in the same boat here. i'm looking at the s-03's compared to the pilot sports. anyone have any thoughts here? luke? i know the pilots are more money, but are they worth it? as of right now, i'm leaning towards the s-03's...thanks for any comments
former proud owner:
'98 silver frost svt
#4109 of 6535
build date: 11.13.97
purchase date: 11.13.00
sell date: 12.8.01
15.717 @ 90.95 mph (first run ever)
bridgestone potenza's s-03 pole position* silver painted calipers * black pin stripe * "saleen" location build number in metalic gray * otherwise completely stock
"that was commercial material...i was waiting to see words pop up at the bottom of the screen."
#281689 11/12/01 05:44 AM
E
E
I am kind of leaning toward these very agressive looking tires to add to my 17s. That is when I get them. laugh
After reading the reviews, looking at the numbers, and comparing them to the KDWs I have now, they appear to be the perfect tire.
Their treadwear rating seems to be higher than that KDS too, which would lead me to believe that they would last longer.
Luke, what are the treadwear ratins on the S-03s vs. the KDWS?
2000 SVT Contour - Silver # 1675/2150
svt1675@comcast.net
This Shine brought to you by the letter "Z" for Zaino
#281690 11/12/01 05:41 PM
ASSVT Offline OP
I'm not Luke but IIRC the S-03's have a 220 rating as opposed to the KDW's 300.
On a side note Luke did you get my message? need to order S-03's today. laugh And I was hoping to be able to deal with you.
2558/2760
born on 08/06/99
Moderated by  1314_dup1
