Posts: 356 |
luke i am in need of your'e infinite tire knowledge. i will soon be needing new tires and i have narrowed it down to two. potenza S-03's 205/50/16 or the stock KDW's 215/50/16 i guess main question here is are the S-03's worth $28 more per tire? i am a rather aggresive driver and live in ca so no severe weather. any and all insight greatly appreiciated (sp?
99' tropic green SVT 2558/2760 born on 08/06/99 KKM, resonator removed, B&M short throw, SHO shop y-pipe w/cat, Pioneer deck, Boston Accoustics 10" rallys, MTX thunder amp
Posts: 2,657 |
My names not Luke but I doubt you'll mind if I chime in. I've been looking at Ultra performance tires for next dry season(Denver)and the s03's are at the top of my list. I thought I saw them in a 215 size on tire racks site but maybe not. Have you considered upsizing to a 225 in the s03s? I know they make those.
Posts: 972 |
S-03's are seriously the best non drag tire you can get for serious traction, nothing is stickier, i would get them if i had money to replace them every summer (sticky read=no treadwear)
95 SE Champagne Mettalic True Dual exhaust with X pipe and Redline mufflers KKM Tru Rev intake H&R Springs/KYB struts Apex-i S-AFC 65mm Throttle Body 17" Ace Spades 4 Pt Racing Harness Window Tint all around New Engine @ 117k kilometers G-Tech: 15.6 @ 91.5 MPH
"you officially kick ass" quote from awed CEG'er after i chopped my hood and threw on scoops
RIP 98 SVT silverfrost *nov 4 2001*
Posts: 356 |
thanks for the info guys!! i now have dunlop sp 8000 225/50/16 it seems to clear no problem. from what i have been reading S-03's are the way to go. now just need to figure out should i go with 205/50/16 or 225/50/16. teh 225 are like $20 more eack IIRC. oh well decisions decisions. once again thanks for the replys
Posts: 442 |
The S-03 Pole Position is the best tire money can buy !!! it is most assuredly worth the extra $28 bucks
Luke
Luke Pavlick Sales Representative ASE Certified Master Tech For more info on any post or to place an order please call 800-428-8355 ext. 362 for on-line orders mention my name in the previous contact field for prompt personal service. www.tirerack.com I want to die peacefully in my sleep Like my Grandfather Not screaming and frightened like the passengers in his car !!!
Posts: 356 |
thanks luke! might be trying to get in touch with you soon to pick up a set.
Posts: 324 |
Originally posted by ASSVT: thanks for the info guys!! i now have dunlop sp 8000 225/50/16 it seems to clear no problem. from what i have been reading S-03's are the way to go. now just need to figure out should i go with 205/50/16 or 225/50/16. teh 225 are like $20 more eack IIRC. oh well decisions decisions. once again thanks for the replys Just wanted to add that you might not want the wider (225) SO3s as they seem to run wider than most other brands. I replaced 235 Pirelli Rossos with 225 SO3s and the 225 SO3s were just as wide(if not wider) as the 235 Pirellis. The SO3s are a great tire and I think you will definitely like them, just wanted to warn you about the width - which may cause you to have serious rubbing issues.
Posts: 288 |
i am in the same boat here. i'm looking at the s-03's compared to the pilot sports. anyone have any thoughts here? luke? i know the pilots are more money, but are they worth it? as of right now, i'm leaning towards the s-03's...thanks for any comments
former proud owner: '98 silver frost svt #4109 of 6535 build date: 11.13.97 purchase date: 11.13.00 sell date: 12.8.01 15.717 @ 90.95 mph (first run ever) bridgestone potenza's s-03 pole position* silver painted calipers * black pin stripe * "saleen" location build number in metalic gray * otherwise completely stock
"that was commercial material...i was waiting to see words pop up at the bottom of the screen."
Posts: 2,847 |
I am kind of leaning toward these very agressive looking tires to add to my 17s. That is when I get them.  After reading the reviews, looking at the numbers, and comparing them to the KDWs I have now, they appear to be the perfect tire. Their treadwear rating seems to be higher than that KDS too, which would lead me to believe that they would last longer. Luke, what are the treadwear ratins on the S-03s vs. the KDWS?
Posts: 356 |
I'm not Luke but IIRC the S-03's have a 220 rating as opposed to the KDW's 300. On a side note Luke did you get my message? need to order S-03's today.  And I was hoping to be able to deal with you.
