Posts: 1,041 |
Sorry early morning. Yeah I dont know what it is...
Silver 98 SVT Contour E0 #4124 (Currently on Life Support) Built 11/97 Bought 1/98 Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI "Come Out...Come Out Where Ever You Are" http://www.geocities.com/speeddemons19
Posts: 2,061 |
Originally posted by Speed Demons: 17 x 17.5 Rims Sheesh... How'd did you fit those?
Dave Andrews Black&Tan 2000 SVT 225 of 2150 Bassani.. UNCORKED davelandrews@comcast.net "Nothing is so firmly believed as what we least know." -Montaigne
Posts: 3,562 |
235/40/17's on mine, still get a slight "ROMP" if it's a big bump, but it's not the metal any more, it's the plastic liner. Get the right offset and a 245 would be possible.  Correct offset and coilovers would fit a 255 in the rear, but not quite sure about the front turning at full lock with that wide of one on there. Will be doing some more measuring before doing that though.  Would at least have to drop to a 35 or maybe even a 30 series tire to keep the height down to manageable levels.
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 1,108 |
Originally posted by bnoon: still get a slight [b]"ROMP" if it's a big bump, but it's not the metal any more, it's the plastic liner.[/b] My plastic rubs also.
Kick Ass don't Kiss It
Posts: 1,831 |
Originally posted by Daveandrews:
Sheesh... How'd did you fit those? What's the big deal people run 18x8's ya know :rolleyes:
Posts: 197 |
I have 205/45/17x7's with Konis and Eibachs and the Konis set pretty tight and I still get rub on the plastic liner in the rear.
Former Owner--98 T-Red SVT
Current Owner-- 2002 VW GTI 1.8T--5 Speed-Reflex Silver-Black Leather
87 S-10 Blazer 4x4(Winter Ride)
Posts: 3,562 |
Originally posted by ZetecToSVT: I have 205/45/17x7's with Konis and Eibachs and the Konis set pretty tight and I still get rub on the plastic liner in the rear.  Offset has to be to small on those then, somewhere around 35mm I'd imagine. Get some with 42 or so and you'll be fine.
Posts: 2,906 |
Originally posted by ZetecToSVT: I have 205/45/17x7's with Konis and Eibachs and the Konis set pretty tight and I still get rub on the plastic liner in the rear.  Dayum, you must have a messed up offset. Just put 215's on my car and they don't come anywhere close to rubbing.
Josh Aka Spectra SVT 02 Dark Highland Green F-150 XLT Mods: Gunrack and cowboy boots
Posts: 1,421 |
i used a baseball bat jacked the car up a bit n bent it up
97 gsxr lotsa good stuff 4 sale 95 talon tsi awd turbo loaded sold 95 se 2.5 mtx loaded (fragile handle with care)2 motors 3 trannies custom y with hi flo cat,custom dynomax exhaust,upper cat mod superchip,udp,bat\kkm,proflow maf,ford 9mm wires,svt throttle body,svt intake manifold ,custom kevlar clutch,16 pd. flywheel,svt motor mounts ,svt gauges,eibachs\h&r,omp strut brace,dark chrome 16" rials with 225/50 dunlops,cwazy amounts of audio
Posts: 227 |
this wil help a lot out(me) picture the rear tire as a clock at what hour would i have to pound out? 12oclock? 9:30ish? where??
pauli18@aol.com for questions 99 green svt asp udp b-n-m short throw kkm intake n the list grows steadily
