Page 2 of 2 1 2
#278905 05/23/01 04:48 PM
JVT Offline
Chris,
thanks for the compliments.
Good luck searching.
John
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
-faster than the above
---wanting a Speed Triple or Superhawk badly
#278906 05/25/01 12:37 AM
Originally posted by Silversvt:
:p Uuh, the [b]HTH meant "Hope This Helps"... Hehe wink wink
[/b]
Oops smile Wasn't paying attention, Silversvt.
Thanks for the info.
#278907 05/26/01 12:31 AM
Originally posted by andy v:
a 7.5 inch wheel with a 45mm offset gives about the same effective center as a 7 inch with a 42mm offset.
Will the tire wear quickly on the inside still? Any drawbacks to a 45mm offset?
5 speed MTX /KKM Custom Intake /Dynomax Super Turbo /TH Fix /Audi A6 Sidemarkers / Badgeless /Audio:(JBL600.1 amp,Polk Dx Subs, Infinity 6953i 6x9's, Lightning Audio Strike Cap)
#278908 05/26/01 02:37 AM
JVT Offline
No, the higher the offset, the better.
You should be OK if you don't go under 40mm.
John
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
#278909 05/26/01 03:56 AM
you can go up to a 19x8 40 mm offset with a 235/35/19 tire
the offset is the most important thing when buying wheels
#278910 05/26/01 06:12 PM
JVT Offline
You can easily fit a 35mm offset, but tire
wear is a concern.
Even w/ my 40mm offset, and 7" wheels, I get
inside tire wear.
Craig, don't be surprised if the same thing
happens to your Cougar. Excessive inside
tire wear on the fronts.
This is why we need C/C plates. Badly.
John
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
#278911 05/28/01 08:42 AM
I'm using 7,5" with 215/45 on my lowered Mondeo but it is VERY close to the rear right wing. It is "rubber touch" when driving on bumpy roads. The offset is 35mm. Offset 40mm would fit better as already said in messages above.
1997 Mondeo Station wagon diesel
lowered on 17" wheels
walnut dash
...need more power to the engine
#278912 05/28/01 08:43 AM
walnut dash
Page 2 of 2 1 2
Moderated by  1314_dup1
