#278895 05/22/01 12:36 AM
Hello
Has anyone tried a 7 1/2" wheel on their Contour? Just wodering what offset you used and whether this rim width causes the dreaded tire touch. I am hoping to use 215/45/17 tires too.
TIA for your responses.
#278896 05/22/01 01:43 PM
E
E
from what i've seen and heard, no it doesn't...i use that same tire size with 17x7 with no problem - but you know how our cars are, some have problems and others don't....
#278897 05/22/01 03:54 PM
JVT Offline
I had 17x7.5 BBS RX wheels (same on the gold
PPG Pace Car in the gallery) with a 35mm offset, and I wore the insides of my tires
within 5k miles. They basically went bald.
Too low of an offset, and them being 7.5" didn't help. I would go with 7" just for
good measure, and a offset higher than 40mm.
BTW, the tires wore out even before I got
my car lowered. Now I'm running a 7" rim
and a 40mm offset. Tires still wear quick on
the insides, but not NEARLY as bad as with
the BBSs.
Hope this helps.
John
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
-faster than the above
---wanting a Speed Triple or Superhawk badly
#278898 05/22/01 04:55 PM
the BBSs.
Hope this helps.
John
The choice for 7 1/2" wheels is a forced one. I am looking at getting Team Dynamics RIM2000 wheels and they only come in a 7 1/2" width.
I would prefer 7" and a 40mm offset, guess I'll just have to keep looking for a 7" wheel that I like. I am primarily looking for a 5 spoke wheel. Any suggestions?
TIA
#278899 05/22/01 05:19 PM
My 18's are 7.5" width with a 43mm offset. No rubbing even with my 2" drop. laugh Oh, the rubber is 225/40 Toyo T1-S.
HTH,
#278900 05/22/01 05:54 PM
JVT Offline
Chris,
click my link in my sig to see my wheels.
Dunno if you like them or not, but they are
7" w/ 40mm offset.
John
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
#278901 05/23/01 02:19 AM
Chris,
7" w/ 40mm offset.
John
John
When I first saw your SVT, all I could say is WOW. Problem for me is getting these wheels in Canada. It's hard to Konig's in this area and I was told by our supplier that this wheel has been discontinued. Whether that is true or not, your wheels were my first choice.
Very nice package you have.
#278902 05/23/01 02:21 AM
HTH,
HTH, that is very good news. I was given the choice of a 45mm offset. I suppose that should be reasonable as not to touch the struts.
Thanks for the info.
#278903 05/23/01 06:04 AM
a 7.5 inch wheel with a 45mm offset gives about the same effective center as a 7 inch with a 42mm offset.
Andy V.
99 SE Sport SGTO
KKM,No Res,Dual exh.
17" Cellos-225/45/17 Sumitomos
vannanthony@hotmail.com
Semper Fidelis
#278904 05/23/01 02:16 PM
:p Uuh, the HTH meant "Hope This Helps"... Hehe wink wink
Chris, we didn't check the back clearance with the strut when we mounted the wheels as I have the GC coilovers... plenty of room there. My gut feeling is that you'd great with 45mm offset on a 7.5" wheel though.
Moderated by  1314_dup1
