#278761 05/16/01 08:53 PM
ST200 Offline OP
Are there any negative side effects in running a different ET(offset) for the front and rear wheels? Tire wear, handling etc.?
The reason Im asking is that the wheels im looking at have a ET of 35 (stock is 49.5) and these would fit finely in the rear where the stock-wheels are quite deeply inside the wheel wells but the front wheels would probably be sticking out too far (the wheels aren't allowed to stick outside the bodywork over here). The shop then told me about something that they could do to the wheel (don't know the correct term for it), basically they carve off 3mm's from the wheel so the offset becomes 38 and it would tuck in fine under the wheel well.
Also, I don't know how similar the wheel wells are for the Contour/Mondeo but how would this affect a possible lowering of the car in the future?
Thanks for any info you might have!
debadged signature
#278762 05/16/01 08:55 PM
ST200 Offline OP
sorry forgot,
the wheels are 18"x7", and tires will be 215/40-18.
debadged signature
#278763 05/17/01 06:29 PM
not a good idea the tires would rub with a 35mm offset and shaving material off of a wheel damages the structural integrity of the wheel
Luke Pavlick
Sales Representative
ASE Certified Master Tech
For more info on any post
or to place an order please
call 800-428-8355 ext. 362
for on-line orders mention
my name in the previous
contact field for prompt
personal service.
www.tirerack.com
I want to die peacefully in my sleep
Like my Grandfather
Not screaming and frightened like
the passengers in his car !!!
#278764 05/17/01 07:28 PM
ST200 Offline OP
thanks for the reply.
they are going to crank out all the wheels to the offset of 38 and it looks as though I should'nt get any rubbing.
And also they are giving me a warranty for the wheels incase anything goes wrong.
debadged signature
#278765 05/18/01 12:39 PM
Still, 38mm offset seems borderline to prevent rubbing. My 18X7.5 wheels have 43mm offset and they don't rub at a 2" drop. They touch the inner fender liner at full drop (coilovers) if I've got people in the back seat but never the metal fender lip.
Just a little heads up.
Moderated by  1314_dup1
