Posts: 620 |
Hello, just a quick question (hopefully). From what I understand, the offset for the stock 16x6.5 SVT wheels is +47mm. Is it the same for the Cougar 16" wheels? I've looked around and some people say it's +42, while others +47.
Black '98.0 GL V6/MTX, tints, SVT airbox (sans fender boot), stock muffler replaced with spiral racing muffler, A6 side markers, Cougar 16" polished wheels w/ bald 205/50/16 Yoko A520's, Mobil 1 5W30, Castrol SATF/Ford FM tranny cocktail, 9005 high-beam bulbs all around, re-aimed stock foglights
Posts: 4,528 |
Posts: 4,042 |
Originally posted by todras: Offset is 42 for both. I must disagree. Looking at my stock wheels, 49mm is what is STAMPED on them. John
Posts: 4,528 |
Oh poo I swear it was 42 John. I've been wrong before though. Only once but I was 5.
Posts: 46 |
Originally posted by Gerald: Hello, just a quick question (hopefully). From what I understand, the offset for the stock 16x6.5 SVT wheels is +47mm. Is it the same for the Cougar 16" wheels? I've looked around and some people say it's +42, while others +47. I too would like the straight poop on what the stock offset is on the SVT wheel. It is quite important when dealing with availibilty of aftermarket wheels. I assume a range is acceptable, but what range? Thanks.
87 honda civic si 88 bmw m3 89 alfa milano 3L verde 98.5 ford contour svt 93 honda NSR 250sp
Posts: 250 |
EO wheels have a 49.5 mm offset according to the Ford factory video that compares the differences between SVT Contours vs. other Duratecs. (Tape is posted in classifieds under miscellaneous.)I would expect E1 wheels to be the same, but can't point to a specific reference. Mark
Posts: 620 |
Thanks for the info guys. Might not have reached a consensus but I'm satisfied that they're within the "acceptable range".
Posts: 65 |
Focus and contour are the same 4 lug 108 offset. Im not sure if the cougar fits in that but I would think it would. Brian Originally posted by Gerald: Hello, just a quick question (hopefully). From what I understand, the offset for the stock 16x6.5 SVT wheels is +47mm. Is it the same for the Cougar 16" wheels? I've looked around and some people say it's +42, while others +47.
2000 SVT Green KKM True Rev Pioneer 6200 Head Unit Rockford 800a2/600a4 amps Infinity kappa's/Polk 12" dx128 subs Short throw shifter/Voodoo Knob ADR Revolution Rims Toyo T1S 215/45/17 Bassani Cat Back
Next Mod: SHO Y PIPE/Diablo Chip
Posts: 17 |
I have seen on the cougar forums board where someone replaced stock 'tour wheels with the stock polished cougar wheels. Our wheels "I own a roush cougar", are 4x108 and the offset is +42mm. hope this helps
'99 Roush Stage 2 Cougar custom grilles and stereo and YES its a COUGAR
