#278499 05/09/01 12:19 AM
I am buying new wheels but need to submit all the OE specs to Tire Rack so they can figure what will clear the Wilwoods.
I primarily don't know the offset and bolt pattern.
If someone knows all the specs for the early cars' flat-faced, 6-spoke wheels (I don't know if that is a good description), that would be great.
1996 Contour SE, 5-speed, Black
A'PEXi S-AFC, Scorpion cat-back exhaust, MSDS Headers, SHO Shop Y-pipe, Fidanza flywheel, Quaife ATB differential, itg foam filter, Magnecors, Koni's, Eibach's, Sparco front strut brace, SHO-shop rear strut tower brace, BAT 22mm rear anti-roll bar, Wilwood Dynalite 4-piston calipers, SVT size rotors, Aeroquip brake lines, 17" OZ Superleggera's, Dunlop SP Sport 9000's
#278500 05/09/01 12:57 AM
Call and talk to Luke at the tirerack. 800-428-8355 ext. 362. He knows everything you need to know. And what are Wilwoods? Do you mean "wheelwells"?
1991 GVR4
Lots of mods done.
#278501 05/09/01 02:34 AM
Wilwood= aftermarket brake upgrade
Josh
Aka Spectra SVT
02 Dark Highland Green F-150 XLT
Mods: Gunrack and cowboy boots
#278502 05/09/01 05:13 AM
I am assuming you're moving to 17" wheels to
clear your aftermarket calipers (nice choice
BTW). For a 17" by 7" wheel you're looking at
a 40 to 42 mm offset ideally. Bolt pattern is
4x108mm no matter what; the offset will be a
little different on a 7.5" wide wheel though.
I second the recommendation to contact Luke,
he's the guy to talk to at the Tire Rack when
it comes to wheels and Contours.
T.
#278503 05/09/01 08:39 PM
The billet aluminum calipers from Wilwood that you are using require a minimum of 20mm more clearance (actually it's 19.4mm) according to the brake/caliper profile from Wilwood. The OZ Superleggera has an additional 25mm so this will work perfectly. On a side note since you are dropping so much unsprung weight the braking enhance that you have made will be much more effective.
Luke Pavlick
Sales Representative
ASE Certified Master Tech
For more info on any post
or to place an order please
call 800-428-8355 ext. 362
for on-line orders mention
my name in the previous
contact field for prompt
personal service.
www.tirerack.com
I want to die peacefully in my sleep
Like my Grandfather
Not screaming and frightened like
the passengers in his car !!!
Moderated by  1314_dup1
