Semaj Offline OP
errr... how much do stock svt rims weigh???? Thanks.
99 SVT #2336
Silver Frost/Midnight Blue.
Leda Coilovers.
K&N Drop-In Air Filter.
Quaife ATB Differential.
B&M Short Shifter.
PIAA Superwhite 9005 + 9006.
Dyno Proven: 180hp/164lbft.
E0 rims - 19 lbs
E1 rims - 18 lbs
Dan
99SVT - Tropic Green
#554/2760
Stock - except minor intake, exhaust, & motor mount enhancements
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
Semaj Offline OP
thanks
99 SVT #2336
Leda Coilovers.
B&M Short Shifter.
Dyno Proven: 176hp/162lbft.
Spring '01:
Grizzly Pro-Lok Race Clutch.
Fidanza 7lb Billet Flywheel.
99 SVT #2336
Leda Coilovers.
B&M Short Shifter.
Anyone know about any of the non-SVT wheels? I am just curious.
Dan Parmelee
TheContourGuy@aol.com
95 SE ATX
KKM
24V HIGH OUTPUT badging
SVT E0 wheels/tires
yellow calipers
CEG stickers
OF's TH fix
HyperWhite high beams
CoolBlue low beams
drilled metal pedals
faux metal grille
removed hoodliner
01 Infiniti I30t
95 Ford Windstar LX
http://hometown.aol.com/thecontourguy/contour.html
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
The numbers I have are:
E0: 21-22 pounds
E1: 19-20 pounds
T.
Y
Y
What is the weight stock rim?
8 Spoke SE rims
7 Spoke
6 Spoke
Larry Carrera
larry_carrera@hotmail.com
CEG Member
Chicago branch
[This message has been edited by Y2k SE Sport (edited April 19, 2001).]
Larry Carrera
CEG Member
Chicago branch
Moderated by  1314_dup1
