Posts: 7 |
I took my resonator out yesterday and it sounds great. The exhaust note is much lower and louder. Rasp goes away w/ in a few minutes. Now my ride sounds like a F*ckin' SVT!!!!
1998 T-Red CSVT custom emblems carbon fiber sails 24V badges removed door ding strips removed chrome painted grills tinted out 20% resonator removed cleared headlights
Posts: 803 |
Mine is not an SVT, but I took mine off too. I was told by some that it doesn't rasp on a normal v6. When I took it off there was no rasp at all, so I was a believer. Unfortunatley I did this all while the cars cats were slightly plugged. ( I wasn't aware at the time) Long and short I just got the cats repaired and the exhaust is flowing right again and yes when cold there is a rasp. When warm it sounds quite nice and deep, but there is a drone. I'll live with it for now but when the weather turns cold again I may need to put a hi flow or a glass pack in.
hunter green 96 mystique mtx, sabb side markers deep tints car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
Posts: 32 |
thanks fot all the info, if i do it ill let everyone know what i think
1998 Silver Contour SVT K&N Filter Rest is stock
Posts: 116 |
I'm not sure of the correct terminology here for sure, but the 'resonator' is the one located at mid-ship on the car, and the muffler is the one in the rear? Is that right? Well, I removed the one at the rear, and added a new elbow section of pipe and installed an oval chrome resonator tip off of a wrecked Porsche944 onto it. And I left the muffler/ resonator (?) unit that is in the middle of the car installed. I really like the sound now though. It has a very deep low sound (due to the long hollow tailpipe that leaves the first old muffler. It does have a rasp when cold though, but when warm, it sounds really good and the rasp is gone. I just use that as inscentive to never get on it until it is warmed up (engine lasts much longer anyway if you don't beat on it when it's cold)
'95 CONTOUR SE -Enkei 16s -Porsche944 Exhaust tip - Audi xenon projector headlights -Peterbilt 30" air horns -mp3 Aiwa headunit (150 songs on one disc) -dual 10s -soon to have LED tailights (real kind, not just gay bulbs) -That's it for now
Posts: 304 |
Originally posted by LiquidSVT: Thanks alot, i want a deeper sound more like a mustang, what is drone...and rasp? A tiny V6 is never gonna sound like a bigger V8. To a certain extent (however small), the engine's displacement has something to do with the sound of its exhaust. Then of course, the number of cylinders, V or I engine configuration, design of the exhaust manifolds, etc., etc. I plan to remove my resonator to see if I like the sound. If not, I'm going to check out Toadster's Edelbrock RPM 5542 performance muffler idea. Karl
*** It's all about consistency! ***
98 SVT Contour 86 Ranger GT 69 Fiat 850 Sport Spider 67 Formula-S Barracuda
Posts: 620 |
Originally posted by Josch: Well, I removed the one at the rear, and added a new elbow section of pipe and installed an oval chrome resonator tip off of a wrecked Porsche944 onto it. And I left the muffler/ resonator (?) unit that is in the middle of the car installed. I really like the sound now though. It has a very deep low sound (due to the long hollow tailpipe that leaves the first old muffler. It does have a rasp when cold though, but when warm, it sounds really good and the rasp is gone. I just use that as inscentive to never get on it until it is warmed up (engine lasts much longer anyway if you don't beat on it when it's cold) I took a similar approach to you, except I replaced the rear muffler with a spiral muffler similar to the Moroso: Moroso Spiral Flow muffler  The sound is louder than stock however it does not have the loud deep bass of an SVT exhaust without resonator or with resonator replaced by a glasspack. It does have a more aggressive, higher-pitched throaty tone which is unlike any other Duratec I have heard. According to Moroso, that muffler design employs noise cancellation which is something that would affect the lower frequencies more. Hence my lack of deep bass. I would like to try replacing the resonator with a high-flow muffler/resonator in the hopes of deepening the tone but without making it too much louder overall.
Black '98.0 GL V6/MTX, tints, SVT airbox (sans fender boot), stock muffler replaced with spiral racing muffler, A6 side markers, Cougar 16" polished wheels w/ bald 205/50/16 Yoko A520's, Mobil 1 5W30, Castrol SATF/Ford FM tranny cocktail, 9005 high-beam bulbs all around, re-aimed stock foglights
