N
Noto77 Offline OP
N
Ive got a 2000 SE Sport with 15" rims. I want to move up to 16" or possibly 17". I know the SVT has 215/50-16 but I was wondering if 205/55-16 would work better. I want to keep the same circumfrence as the 15's so my speedo stays the same. Thanks for any help.
2000 SE Sport
Toredore Red, MTX
1994 Dodge Stealth R/T Twin Turbo
320HP Stock
2000 SE Sport
Toredore Red, MTX
Clarion Pro Audio CD H.U.
Pioneer 3-ways
Carbon Fiber Grill Trim
You didn't state the size of your 15s, but I
suspect 205/55-16 is going to be closer. The
1998 SVT runs this size (they changed it to
215/50-16 to sharpen things up a bit more).
You can compare your tire sizes using a tire
size calculator. There's one on this site you
can use:
http://www.miata.net/garage/
It'll help put your mind at ease about change
in the speedo readout.
T.
You can also use 225/50R16. That is what I have on my 98 E0 SVT
Jim Johnson
98 SVT
Jim Johnson
98 SVT
I have a 98.5 SE Sport and upgraded to 16" Mille Miglia EVO's, they look great! And went to 205/55/16 Firestone SE 50 EP, awesome tires!! These tires have great cornering characteristics on dry AND wet pavement! Very little difference according to the Miata calculator.
Keith W
98.5 SE Sport ATX
Lt. Denim Blue
Firestone SZ 50 EP's-2nd set!
Free stock filter box mod
Jim,
Will the 225/50R16s rub in the rear with weight in the back seat/trunk? I could have sworn that I saw a comment from Luke that the rear fenders need to be rolled.
Thanks,
Barry Wolf
96 Contour SE
Barry Wolf
1996 Contour SE MTX Midnight Red, Parchment leather
Brakes: Bendix OEM size discs, Carbon Metallic Pads, Parking Brake TSB kit
Engine: New IAC valve, new EGR valve, new cat, new water pump, moose fix kit, K&N drop in filter
Tranny: Redline ATF + Ford Friction modifier
Interior: Pioneer CD receiver, Pioneer speakers, Ford RS shift knob, Ford vinyl floor mats (great purchase!)
Handling: E1 SVT Rims, Yoko AVS-I 205/55ZR16 (like butter) meats
Other: High beam bulbs in low beam position, new trunk vent
Other problems: leaky PS pump - fixed with 2 oz stop leak, 1 quart oil use per 2K miles
Mileage: 62K (August 2002)
Moderated by  1314_dup1
