Doug, Hopefully the backfaces of your new wheels are warped now from tightening them down on the retaining clips. As this would cause the residual vibration you are feeling. Next step is to try rotating the wheel on the hub, i.e. unbolt it rotate 90° slip back on and tighten the lugs again. Make sure you have the right torque too. For 2000 SVT's it's 100ft-lbs, 99's have 95 and 98's have 85. I couldn't beleive this myself but I saw it on a chart at discount tire. Good luck.
