Posts: 83 |
I need to know some sites, manufacturers, tire companies, anything! I also need the bolt pattern on a 95gl contour. I was looking at 17" rims, but ANY input is good. thanks!
-Matt
95 zetec no engine mods 20% tint, limo strip alpine cda7876, alpine dddrive components ddc-r17h, 2 kicker 12L7 in a ported box facing forward and sealed from the trunk air space, zapco limited edition z600 (2) getting the 3-way component set
Posts: 960 |
Best site is the TireRack. www.tirerack.com We use a 4 x 4.25" bolt pattern.
96LX/24V/ATX/Midnight Red/A4 repeaters/SVT exhaust/KKM/65mm throttlebody/SVTsprings and ST200 struts/SE rockers and BAT spoiler/BAT 19mm swaybar/urethane bushings/Kenwood 7 speaker syst./E1 SVT brakes w Powerslot rotors/9005 lowbeams/885 fogs/50% tint/Michelin XM+S 130's for winter/E1's with gForces for summer...and now "New Paint!!" 87 Renault GTA convertible/2.0l/mtx/Sony sound/otherwise stock http://members.shaw.ca/neilmc/
Posts: 83 |
I just saw that it was 4x108, is there a difference between the two?
Posts: 960 |
That's the metric equvilent. The math doesn't quite work but I swear I have 4.25" aftermarkets on my car.
Posts: 442 |
4-108 is the correct bolt pattern Thanks, Luke
------------------ Luke Pavlick Performance Specialist ASE Certified Master Tech for more info or to place orders please call 800-428-8355 ext. 362
Luke Pavlick Sales Representative ASE Certified Master Tech For more info on any post or to place an order please call 800-428-8355 ext. 362 for on-line orders mention my name in the previous contact field for prompt personal service. www.tirerack.com I want to die peacefully in my sleep Like my Grandfather Not screaming and frightened like the passengers in his car !!!
Posts: 83 |
which is more common: 4x108 or 4.25? If i lower my car, will it be ok with both? will 4.25 be ok with all rims? also, is there any other place/company websites that have rims? thanks!
