#27530 07/31/02 05:31 PM
Hi all,
I have a problem with my OBD2 recently my little cousin was playing with it mad
And today I tried to used it but I think one or more pin cable are not with a properly contact, frown
I do not wich of the 9 pins in the serial conector should actually work,
Could you please tell me wich of the pins from the car conector correspond to the serial pins?
How many really shoudl work?, in wich position? confused
Thanks a lot!!!
1998 Contour
V6 2.5L ATX
#27531 07/31/02 06:32 PM
Please !!!
someone with OBD II!!!!
1998 Contour
V6 2.5L ATX
#27532 07/31/02 07:43 PM
Originally posted by ramon1809:
I have a problem with my OBD2...
OBD-II is a specification. It stands for OnBoard Diagnostics and is standard on U.S. vehicles from 1996 onward (and some pre-1996 cars). It is the second version of the spec, w/ OBD-I being the first, and OBD-III coming eventually.
If you have a specific product that you are having a problem with, then I would try to contact the manufacturer of that product. They will know the product better than anyone.
You can try to post a reply here with all of the pertinent info (product name, version #, O/S, etc.), but I am not sure if anyone will be able to help. I guess it won't hurt to try.
Hope this helps.
1996 Contour SE Sedan 4D (Royal Blue)
Duratec V6 2.5L 24-valve DOHC
Automatic
75,000 miles
No Mods (unless you call the DMD a mod)
Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
#27533 07/31/02 08:32 PM
shocked
Well I meant Alex PEper OBD, I'll try with the manufacturer, I just thought it would be faster aks here, tnx anyway
1998 Contour
V6 2.5L ATX
#27534 08/01/02 04:15 AM
Well, after a little research on Alex Peper's web page I think I have a bad answer for you. There is no easy way to ensure your cable is working as the 9pin connector section of the cable has a module inside it that converts the PWM communications into UART.
In laymen's terms, there are no straight through wires and you can't check for continuity from the vehicle connector to the 9pin connector. If you still want to make sure the wires are working, you'll need to break the cable apart to test.
Here are the needed pins on the vehicle connector:
2, 5, 10. If any of those are broken, you're SOL.
Hope that helps!
James
96 Mercury Mystique - Zetec ATX
Mods? Yeah, those cost money...
