#27255 07/29/02 01:47 AM
What types are safe to use. I know my Haynes manual says to use ATF type F fluid, but I was wondering if it would be okay to use the same stuff I used when I swapped my tranny fluid. I used the Mobil 1 AFT fluid when I did my trans.
What do you guys recommend
Thanks
Evan Groenke
1999 Silver Frost SVT #1919
183.9hp 163.7lb/ft tq @ the wheels
Now bitter at Ford
Mobil 1 ATF works great!
2000 SVT #674 - Check it out!
The 95 and possibly the 96 manual specified type F transmission fluid. After that, the manuals specified Mercon transmission fluid. Unofficially Mercon has been used in power steering systems instead of type F for years.
Mobil 1 ATF meets Mercon specs. Mobil 1 ATF is what I use.
Jim Johnson
98 SVT
OK...I've heard so much conflicting info about this...so a bunch of questions: confused
So you're saying that it *is* OK to use Mobile 1 ATF (or any Dexron Mercon ATF) in the power steering units (all years)? There isn't any reason that Ford specified Type F as opposed to Mercon???
Are they fully compatible? (OK to top off w/Mercon if filled w/Type F?) Are we better off switching to Mobile 1? Is Type F recommended at all any more or has Ford decided Mercon is better? What exactly is the difference between Type F & Mercon, anyway?
(I'm assuming it's not a good idea to use regular power steering fluid [labeled PS fluid - not ATF]? But haven't some folks said that they switched to synthetic power steering fluid?)
(BTW, my '95-'98 Haynes Manual specifies Type F for all years.)
'96 Contour SE 2.5L Duratec V6 MTX Teal
Purchased New - 9/95
43,000 Miles - I Know, I Need To Get That Water Pump Replaced!!
K&N Air Filter/K&N Oil Filter, Castrol Full Synthetic Oil - Switching to Mobile 1
Advance Auto Salesperson (When Not Working At My Reg Job [Wildlife Biologist])
(Hey, Why Not - I Get A 20% Discount & Have Access To All The Parts Catalogs!!!!)
Thanks
Evan Groenke
Now bitter at Ford
WTF?
My owners' manual specifies "Ford Spec ESW-M2C33-F" power steering fluid.
I can't find this stuff anywhere. What gives?
"Function before fashion."
'96 Contour SE
Q
qaz Offline
Q
ESW-M2C33-F is a specification...any Type F fluid will probably say somewhere on the label that it meets this specification.
Brian
Originally posted by RogerB:
WTF?
Ford puts those Ford specs in the manual to make you think that you have to buy the fluid from Ford. I bet the first line of that spec says "This specification defines the properties and characteristics of the Type F ATF approved for use in Ford applications" or something of that jist.
OK. I've been looking at power steering fluid in the stores, and most don't list what specs they meet. Those that do, list a different Ford spec than M2C33.
I'll have a gander at the ATF fluid bottles, and also look at my manual again for more details.
One more question, though: If I'm just topping off my system, is there a combination of fluids that might cause harm? That is, if the system contains M2C33 (whatever that is) and I add any old type F ATF, am I going to be OK?
'96 Contour SE
E
E
What the heck is MERCON anyhow?
Is it a synthetic fluid??
I need to change both my MTX fluid AND my power steering fluid.
The local SVT dealer says they've never heard of putting a synthetic oil into an MTX-75 fluid change.
I'm confused...
BIG JIM, help us all, pleeeeease! confused
1998 EO SVT, silver frost, stock
2002 Ashcroft Homes Albany model, that's why the SVT is stock!
