Q
Qbert Offline OP
Q
Well after a long drawn out process between Americas Tire and UPS my race tires finally arrived at the store today. I just had them mounted on my E1's and wow are they BEEFY! If you'd like I can take some pics and show the difference between 215/45/17 street tires and 225/50/16 race tires. I can't wait to go heat cycle them tonight and race on them this weekend!
Current Cars:
2000 CSVT #398 / 2150 - TRed
85 CRX si with a suspension harder then Ron Jeremy on Viagra.
What brand did you get?
I ran that same size on my E1 rims and my front tires looked horrible after 4-5 events....(i even ran very high pressures to compensate for the sides bulging out) .... Mine were Yoko Ao32R s...
I overheated one and chunked it to the wearbars!!! so i need at least two new ones! (any one have any 16" 205's?) smile
Enjoy your new tires! hopefully you will have better luck!
Unfortunately mine were a big $1000CDN mistake frown
Rageboy
Black 99 SVT
#1883/2760
Q
Qbert Offline OP
Q
I bought Kumho Victoracers. I just went out and heat cycled them last night. Holy shiznit I forgot how much race tires grab, it's been 2 years since I had any and the last ones were really old. There is some rubbing on the rear and a tad in the front. That is not a big deal due to the fact they are only pushed for 5 minutes or less.
When I was heat cycling them I could watch when my rear tire lifted going around in a circle. My Brake light would come on every time it came off the ground and stopped rotating. Really fun, I could have held it in the air all night long.
Rageboy:
Did you heat cycle your tires before racing on them? If not you need to do that do get the compound to set correctly.
Current Cars:
Tirerack will heat cycle your tires for a fee. It makes it easy because then they get to rest during the shipping time. I have used the service, and had them shaved and can recommend it. I have found that shaving Kumho race tires to 4/32" and heat cycle to work the best. If I leave the tires at full depth, I lose usable grip long before the tread is gone. At 4/32" the grip and tread go at about the same time.
Respectfully,
Andy Hohl
Q
Qbert Offline OP
Q
Respectfully,
Andy Hohl
Yeah, I would have bought heat cycled ones, but that would have put me over budget. So I just did it myself. I think next time I will order them heat cycled though. It is a big pain in the ass to do it yourself.
Never have bought shaved tires. Maybe when I go back to nationals I'll buy a shaved set, or hoosiers. laugh
Current Cars:
http://www.4113pittsburg.com/Automobiles/ContourSVT/Default.asp
I would expect your car looked something like this.
This is a photo of me at a NeOkla autocross. October 21st 2001. I was running on BFG Comp T/A R1's at the time. I have since switched to Khumo's, only because the BFG's are no longer available.
Q
Qbert Offline OP
Q
Yeah, it probably looked a lot like that. I actually have been lifing my tire with BFG KDW's on the car. I don't have any photo proof, but I have had numerous people tell me. My friend also autox'd my car once and I saw him lift the rear wheel on the KDW's so it should happen a lot with the race tires.
R1's were nice tires. Built in negative camber. I wish Kumho would do that.
Current Cars:
Moderated by  Auto-X Fil
