Page 2 of 2 1 2
#271363 05/02/02 10:07 AM
Flush/drain the system via the two lines to the pas cooler near the rad lower hose/drain plug...
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#271364 05/09/02 12:12 AM
I have also heard that a powersteering cooler should be installed. I haven't done so, but then I haven't had my fluid boil over more than the one time when it was 98 degrees out.
Dave Andrews
Black&Tan 2000 SVT 225 of 2150
Bassani.. UNCORKED
davelandrews@comcast.net
"Nothing is so firmly believed as what we least know." -Montaigne
#271365 05/09/02 03:28 PM
JasonS Offline OP
After reading the replies, I guess that what I though was boiling is actually frothing caused by the high speed of the PS pump. If this is the cause, then a PS cooler wouldn't help at all because it's not heat I'm trying to battle, but foaming of the fluid due to agitation, correct?
What would cure frothing? confused
JasonS
2000 Silver Frost SVT
#1119 of 2150
Eibach Springs / Corbeau Forza II Seat / TRW Sabelt 5-point belts / Pegasus Brake Ducts / Braided Steel Brake Lines/KVR pads / Black SVT Rims / Mirko Racing Front Airdam / Clear Corners / Knauberized
Best Lap Road Atlanta: 1:56.1 -stock KDW tires!!
Page 2 of 2 1 2
Moderated by  Auto-X Fil
