Page 2 of 2 1 2
Question to add to that. What clutch and how long is the stock one good for? Right now I've got about 55k on it. Replace or keep?
confused
'98 E0 T-RED CONTOUR SVT
#558/6535
Got Tunes:
Sony CDXC-90, CDXT-65, XDP210EQ
MCINTOSH MC4000M
BOSTON PRO 6.5 COMPONENTS
BOSTON PRO 12.5 LF
POLK DB4500
STINGER 1FARAD CAP
RED NEON INSIDE AND UNDER
THROTLE HANG FIX
RESONATOR REMOVED
Originally posted by CJFEDERLE:
Yeah if it's dead then the Quaife is what I'm getting. Mabey a new clutch too. And while it's in the shop have the water pump done.
Is their anything I'm missing?
Yeah motor mounts. Get the BAT re-inforcements and also fill up that back mount with silicon. All those holes back there rob you of horsepower and responsiveness.
Congrats on the blown diff. Had a friend of mine out here.. Yankees23(i think that's the right number) just had the same thing happen to him. End of 4th run, he put a tooth through the tranny casing, made it a bit easier to identify the problem. He's out about 2500 labor and all. And don't forget the rental car while this is happening.
Dave Andrews
Black&Tan 2000 SVT 225 of 2150
Bassani.. UNCORKED
davelandrews@comcast.net
"Nothing is so firmly believed as what we least know." -Montaigne
Isn't a rental car just relatives with extra ones laugh
I am happy to have a hook up here and get labor for free laugh probably the only good thing about this.
Thanks to everyone smile
#558/6535
Got Tunes:
MCINTOSH MC4000M
BOSTON PRO 12.5 LF
POLK DB4500
STINGER 1FARAD CAP
THROTLE HANG FIX
RESONATOR REMOVED
Finally car's fixed. laugh
I got a call from the shop this morning.
Nothing but a broken bolt mad
So they didn't even drop the tranny.
Good things:
Only $100.
Get my car back today.
Bad things:
No LSD
No new clutch
No lightened flywheel
So I guess it's next time for all the mods.
Or it a couple grand just happens to fall into my lap. Thanks to everyone for their help laugh
#558/6535
Got Tunes:
MCINTOSH MC4000M
BOSTON PRO 12.5 LF
POLK DB4500
STINGER 1FARAD CAP
THROTLE HANG FIX
RESONATOR REMOVED
Originally posted by Terry Haines:
It only takes ONE TOOTH to come off the diff gears and the drive can be lost.....
Anything to help prevent this...?
Or is just hard driving?
Silver 98 SVT Contour E0
#4124 (Currently on Life Support)
Built 11/97 Bought 1/98
Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods
Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI
"Come Out...Come Out Where Ever You Are"
http://www.geocities.com/speeddemons19
I was suspicious of this assumption that it was a blown differential. I mean, how could it fail while you were stopped and out of gear?
Only event I've seen where you take the car out of gear, then try to put it back in and you get nothing, was when an ex-boss roasted his clutch trying to pull cement up a steep driveway. Once he let the clutch plates cool off, they didn't meet any more.
Maybe in your case, stopping allowed the broken bolt to fall out of its hole...
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
Originally posted by Paul Kienitz:
[b]Nothing but a broken bolt mad
Maybe in your case, stopping allowed the broken bolt to fall out of its hole...[/b]
Real simple I watched someone do exactly that (blown diff) on his second autocross. so it's easy to assume that this was the case here also.
Dave Andrews
Bassani.. UNCORKED
Is this really the dierential and is it really that soft? I've been on the car hard a couple of times but this wasn't one. P.O.S. weak a$$ stock tranny. mad
But thanks for leading me down there, with the exception of my car being dead and the trip back it was a blast. laugh
The diff isn't soft. It's hard. It's brittle, meaning that it doesn't absorb shock loads very well. The diff is designed for high mileage, not high performance. Performance diff's don't last as long because they wear out faster being more ductile.
Hard = high wear characteristics, low strength
Soft = High strength, low wear characteristics.
Considering our tranny is for the Forcus/escort with a 4-banger I can see why the diff is too brittle for our engines.
Glad to see it was something cheap and inexpensive.
Dave Andrews
Bassani.. UNCORKED
O.K. What I meant was by soft was just a brittle piece. Sorry I'm a dumbass. But it's great to have my car back. I hated having to drive this old broken down bronco. oh well laugh
#558/6535
Got Tunes:
MCINTOSH MC4000M
BOSTON PRO 12.5 LF
POLK DB4500
STINGER 1FARAD CAP
THROTLE HANG FIX
RESONATOR REMOVED
O.K. Sorry I'm a dumbass. laugh
Nah.. not a dumbass, I'm just a stickler for correct terms. Something about engineering and all those metalurgy classes..
Most people don't know it.. only us engineering Geeks really care laugh
Dave Andrews
Bassani.. UNCORKED
Page 2 of 2 1 2
Moderated by  Auto-X Fil
