O.K. here's the story, finialy decided to take the tour out and run it. Have had it fir two years and got the itch to run it. Ended up going to Louisville KY for my first meet, about 2 hours away but not too bad. Got there in good time and things were going very well. Mey a few CEG'ers and a bunch of other people as well.
So I start running in the second heat and had 5 runs. First four went great. I started with a 42.454 and by the fourth run was down to 39.366. As I was pluuing through the line I stopped to wait for the guy in front of me, put on the brake and too it out of gear. When I went to put it back in gear I had nothing. No gears at all. eek
The clutch felt fine just a loose shifter. Had to push it out of line and didn't get to make my final run. Ended up in the corner of the lot and couldn't get it in gear. Eventually with the help of alot of people, fellow CEG'ers, Mike, the evet coridonator, david, anne and many others(please psot so I can give you all mad props you were all a great help) we found that the linkage was good to the tranny case. frown eek
So I called home any soon therre was a trailer and truck on the way(three or four hours later). They finally arrived and the car was loaded by 11:30. On the way home the trailer blows a tire around 1:00. Nowhere to get it fixed and no hotel for about 15 miles. frown
We ended up taking the tire and leaving the trailer and contour in a gas station lot. went up the road, got a room and finnally got to sleep about four.
Up around eight and got a new tire, the old one was shredded. Went back and was soooooooo happy that the trailer was still there. But it was still busted.
Dropped it off at my uncle-in-laws shop on the way home and finally got in about 11:30.
What a terriable time.
Just for the record I did have a great time running and will probabally do it again.
Does anyone have an idea as to what is wrong?
Also any ideas on things I should do with the tranny out?
Any help will be much appericeated.
Again thanks to everyone for all their help and support.
P.S. My wife never wanted me to go in the first place. eek
'98 E0 T-RED CONTOUR SVT
#558/6535
Got Tunes:
Sony CDXC-90, CDXT-65, XDP210EQ
MCINTOSH MC4000M
BOSTON PRO 6.5 COMPONENTS
BOSTON PRO 12.5 LF
POLK DB4500
STINGER 1FARAD CAP
RED NEON INSIDE AND UNDER
THROTLE HANG FIX
RESONATOR REMOVED
H
H
You are the next contestant on destroy the stock differential. You will need to buy the Quaife ATB differential for $595.00 from BAT, SPmotorsports, or Terry Haines. With labor about $1200 of a job. Terry is in Michigan, take it to him if you can.
Sorry guy, I led you to Louisville, I don't show up and this happens, frown
98 T-Red Contour LX V6 Mtx 106k miles
9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
Is this really the dierential and is it really that soft? I've been on the car hard a couple of times but this wasn't one. P.O.S. weak a$$ stock tranny. mad
But thanks for leading me down there, with the exception of my car being dead and the trip back it was a blast. laugh
#558/6535
Got Tunes:
MCINTOSH MC4000M
BOSTON PRO 12.5 LF
POLK DB4500
STINGER 1FARAD CAP
THROTLE HANG FIX
RESONATOR REMOVED
It only takes ONE TOOTH to come off the diff gears and the drive can be lost.....
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
H
H
Terry Haines how much is a Ford OEM diff?
If you need to open the case, spend the money on the Quaife. Since the major cost is labor, why not put the best parts in.
You gotta pay the labor anyway, buy the best parts while the work must be done.
TB
Tony Boner
H
H
I was gonna try to sell him my lightly used Ford diff. After I get a Quaife differential installed by Terry.
$200 for the used Diff and $600 for a Quaife diff plus $600 for installation would be $1000 net.
And the guy would get a $200 diff and save $400.
Not a wise choice to go with a used or new OEM diff if you're going to replace it. Just think, you weren't on it hard and it blew, so what happens if you get on it hard again and it blows again? Another $1000 down the tubes minimum even if you figure you managed to save $400 the first go round it will cost you an extra $600 right there. Go with a quaife. If Terry sells and installs it, I am pretty sure he charges less than BAT or anyone else sells it for. FYI, you can ship a tranny to MI for about $75 UPS.
Rick
The first Blown 3 Liter!
"Drive it till the wheels fall off" -my personal motto!!!!
98.5 T-Red SVT #6180
Many Mods
Buckshot77@aol.com
Owner of 00 #1611 Silver
Totalled on 10/7/01
SVT Parts for Sale
I shipped my tranny to Terry from STL for $42 fedex ground. "Next time" I'd get my whole car to him instead...
'98 SVT #2371, silver, keeping it in GS
Yeah if it's dead then the Quaife is what I'm getting. Mabey a new clutch too. And while it's in the shop have the water pump done.
Is their anything I'm missing?
#558/6535
Got Tunes:
MCINTOSH MC4000M
BOSTON PRO 12.5 LF
POLK DB4500
STINGER 1FARAD CAP
THROTLE HANG FIX
RESONATOR REMOVED
Moderated by  Auto-X Fil
