H
H
17.10.F
It does not allow replacement, modification, or substitution of pulleys, cogs, gears, or belts which are part of cam, layshaft, or ignition drive or timing systems, etc. This does not permit replacement of integral pulley-dampener/ balancer assemblies. .
Sorry guys.. frown
98 T-Red Contour LX V6 Mtx 106k miles
9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
It's a Ford factory stock 2.5L part. Only your conscience would know the fact it was not on US 2.5L's. Even then it's a reliability mod vs a performance mod.
BTW - it's not a balancer. Dual Mode Damper
I'm sure that rule was made to prohibit UDP's.
Either way I guess I'm just glad I don't have to play by someone else's rules... :p laugh
2000 SVT #674 - Check it out!
The rule was to also stop lightweight pulleys of the same ratio. The only way the DMD would be legal in stock class competition is IF Ford said the DMD was the new replacement part for the original SMD with the new part number listed as the correct one to use. Hope this helps.
Respectfully,
Andy Hohl
Originally posted by SVTSTS:
The only way the DMD would be legal in stock class competition is [b]IF Ford said the DMD was the new replacement part for the original SMD with the new part number listed as the correct one to use.
[/b]
My understanding is that the DMD has the SAME Ford part # as the original crankshaft pulley.
1996 Contour SE Sedan 4D (Royal Blue)
Duratec V6 2.5L 24-valve DOHC
Automatic
75,000 miles
No Mods (unless you call the DMD a mod)
Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
First, the DMD has the EXACT same Ford part number. Secong, it is a FORD TVD, and not aftermarket. LAst, if they looked at it would they even know it was not stock on the car?
Just call me Judge.
People suck.
Life begins at 170mph...until that point it is just boring.....
I don't autocross, but I doubt even the best tech inspector would know to look for it and be able to identify the originally installed item vs. the DMD. And IF they wanted to squeeze in there and ID the Ford PN, they'd still see the part number originally installed on our vehicles. Unless they read these boards, or were familiar with BAT's catalogue, or compared two Duratecs side by side, there would be no way to know.
It is different than sneaking in a Quaife - this part should have no significant effect on performance as far as I can tell.
READ the words guys...'which is part of the CAM drive etc....the DMD is not part of the cam drive..the bloody chains are ...doh!!!
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
I think you would be hard pressed to find and inspector that would fault you for adding weight considering it has the same exact part number!
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
Just to be clear on what I said, if you were to go to Nationals and be protested for a DMD, if you could show that the DMD was the factory replacement for the SMD, and this means documentation from Ford stating the DMD was the correct replacement part in America, i.e. a TSB or something similar, than you would win the protest. If in fact, since I don't have first hand knowledge, the DMD is the same p/n as the SMD, than it might be wise for someone to get an official answer from SCCA National on its legality. You must remember that in the SCCA, we compete basically on the honor system so be honest about your modifications when you compete. At this point in time, I don't know the legality of the DMD, but since I don't have documentation to say it is legal, then it would lose at protest time. This is all my opinion so please remember that.
Respectfully,
Andy Hohl
1st off, I doubt any of us are going to nationals this year. 2nd thing, I'd like to see the first inspector who could tell the difference.
3rd thing, I only wish I was good enough that it made a difference.
Dave Andrews
Black&Tan 2000 SVT 225 of 2150
Bassani.. UNCORKED
davelandrews@comcast.net
"Nothing is so firmly believed as what we least know." -Montaigne
Moderated by  Auto-X Fil
