Posts: 219 |
Has any one else had a pwr steering fluid leak at the cap after an autocross? The resevoir is quite hot and i am wondering if the fluid is boiling or is the reservoir becoming pressurized due to the quick steering inputs of the autocross and blowing it out the cap. Any ideas? TIA Andy
Posts: 138 |
I started autox this summer and never had a problem with the pwr steering fluid. I'm thinking that you have a problem with the power steering system. Especially since you say it is "hot" not warm. Depends on the weather also. I'll be curious to see some other input also.
Frank McGovern 99 SVT Silver Frost 620/2760 mcgovernf@earthlink.net
Posts: 505 |
Mine does it too. I first noticed it last year and had the bottle and cap replaced under warranty at the end of the autox season. It started doing it again this year and I took it back to the same dealer. They said the resevoir was overfilled and removed some fluid and pronounced it fixed. Funny, it had slightly less fluid in it than when they filled it the last time they worked on it. :rolleyes: I suspect the fluid is boiling. When I complete a run the rack makes a lot of groaning noises.
Chris
Chris 2001.5 Dodge Ram/Cummins 2500 1986 SCCA/ITS RX7 roadracer
2001 KY Region and Tri-Region STS Champion
Posts: 2,061 |
Interesting, I'd like to hear more on this. Mine never seems to be a problem. Last event was over 95 degrees for the day too.
Dave Andrews Black&Tan 2000 SVT 225 of 2150 Bassani.. UNCORKED davelandrews@comcast.net "Nothing is so firmly believed as what we least know." -Montaigne
Posts: 219 |
The problem occured this past weekend at a divisional in Topeka, KS. The temperature was 100 degrees w/ 115-120 heat index. Most of the run was at 4K rpm or higher. It was a speed course with 2 high speed slaloms, lane change and various turns. The time on course was approx. 58 sec. each day. There were a lot of elavation changes also. This was the first event on the new Bridgestone S-02 Pole Positions instead of the BFG KDWs, so the extra grip may have been a contibuting factor.
Posts: 3,567 |
just take the return line of the power steering system and pipe it through a radiator mounted auto trans cooler and the oil will never get hot.
"careful man, there's a beverage here." e-mail: boseraq@hotmail.com aol IM: madhat1412
Posts: 2,061 |
I run on R1's so I doubt the extra grip is a factor. The only thing I could see being a problem is the 100 degree day.
Posts: 574 |
Yes, the power steering fluid boils on hot days. I noticed this after driving around town and popped the hood right after to check something, and the fluid was boiling. It was about 95F outside. I haven't autocrossed it yet - this was just from driving around town, a bit aggressively, but nothing crazy.
'96 Contour SE, black / opal grey, MTX, every option, KKM intake, resonator removed, Flowmaster Series 40 DeltaFlow, GoodYear Eagle HP's, 115k miles, new paint 7/01. Driven cross-country 4 times.
'70 Corvette Stingray Coupe, Cortez Silver, 454 bored to 462, Muncie M21, too many mods to list, lots of fun. 335 rwhp / 365 rwtq
'02 Corvette Z06, Electron Blue / Black, every option. Stock for now...
Posts: 332 |
Yes, there wer 3 Contour SVT's on the track last week here in Detroit and 1 boiled over quite a bit while the other 2 showed signs of slight boil over. Temperature was around 80 that day and we ran for 30 minutes at a time.
Posts: 2,061 |
This is not something I like hearing.
