Posts: 117 |
Are any of you guys using a 4 point harness? If so, what brand, where did you buy it and how is it mounted?
Thanks
------------------ 99 Black&tan SVT #308 Borla Catback, K&N, Konis and H&R's on order Blaupunkt 91 Audi Coupe Quattro (winter fun 68 Mustang Convertible (summer fun)
99 Black&Tan SVT #308 - For sale Borla Catback, K&N Blaupunkt '01 Audi S4 Avant yeeehaa!! 91 Audi Coupe Quattro- For sale 68 Mustang Convertible (summer fun)
Posts: 336 |
Krause,
I just use a wide lap-belt I picked up at a performance parts place. It costs about $20 and works great. The big plus is that you don't have to install/uninstall after each event...the belt just tucks away beside the seat. I highly recommend it if you are just looking for something to hold you to the seat during an AutoX event.
The Mark #464 of 6535 A Few GS-ish mods
Posts: 160 |
I fabricated a Lateral Support Seat Belt, which is a piece of band iron with a male and female seatbelt attachments welded on to each side of the iron bar.
How it works is when i am in grid at an autoX I Take it from the rear of my seat and wrap it around me from behind the seat and it holds me directly in place against my seat. It is awesome, it holds me upright very well, I never find myself struggling to hold myself up. It is Completely Wrapped so it doesn't damage the seat.
I will be selling this Seatbelt soon Because I am getting a 4-point Harness for my b-day because it is a little more intimidating than the fabricated lateral belt... anyone interested...?
_evan
98 E1 SVT SOLD New 99 E1 SVT#2468 of #6535 #1958 of #2760 No Cat B&M Short Shifter No Res All Stock... B&M Short Shifter NEW Kumho Ecsta Treads Mobil 1 lube Mesh Grilles All Around KKM Aluminum Pedals w/ Custom Aluminum Dead Pedal Black Calipers w/ White SVT SVT Carbon Fibre Sail Panels Door Dingers removed Xenon bulbs all around BNM white faced hvac 35% tint all around Valentine One Pioneer 8200R Alpine 6.5's in doors http://Lightwave.Silverbox.Net/Racing Race That Snazzy Contour?" "If it can do it, It was designed to."
Posts: 13 |
I use a 3-pt. Scroth with Momo pads. I don't recall the name of the place that I bought it, but it was via the Internet for about $105. I used it in 2000 and added some Momo pads from SPMotorsports for this year to make it more comfortable (old guys need comfort).
I mounted it by putting the two thick eye-bolts that come with it into the rear of the driver's seat frame rail (had to take off the plastic coverings to do so). Drilling the holes out for installing the bolts was tough...those frame rails are HARD! I then clip the connectors over the two eye-bolts for races and clip the third one (top) into the rear seat-back retaining thingy and slam the rear seat into place. It works great.
If there's interest, I'll snap a couple of digital pix and post them to show what I mean.
Mike
98.5 E1 Black/Blue a few sneaky mods
Posts: 1,611 |
Originally posted by GS8: I use a 3-pt. Scroth with Momo pads. I don't recall the name of the place that I bought it, but it was via the Internet for about $105. I used it in 2000 and added some Momo pads from SPMotorsports for this year to make it more comfortable (old guys need comfort).
Mike I would like to see a couple pics of your install, as I am planning to put in a harness in the near future. You can post them or send them to my email adress in my sig. Thanks, Rick
The first Blown 3 Liter! "Drive it till the wheels fall off" -my personal motto!!!! 98.5 T-Red SVT #6180 Many Mods Buckshot77@aol.com Owner of 00 #1611 Silver Totalled on 10/7/01 SVT Parts for Sale
Posts: 301 |
I have a 3-pt Scroth Rallye3 with some custom anti-sub straps (makes me a 5-pointer).
For the rear points, I simply used the rear frame rail bolts. Just remove the rear bolts, slide the harness brackets underneath the rail (lining up with the hole of course), and put the bolts back in. I also put a washer in the other rear bolts to keep the surface level. I didn't want to tighten them down and bend the rail. Takes about 3-5 minutes to install/remove. 10mm ratchet and phillips screwdriver is all you need.
Rear point is the center lap belt point. Pull the rear sear (bottom cushion) out of the way, use a #55 'star' wrench and unbolt the bolt. Slip in the rear bracket and put back together.
The sub straps are triple-wrapped around the 1/2" bar underneath the seat. (part of the seat frame). Helps keep the lap belt from riding up when you tighten up the shoulder harness.
Clear as mud?
It's worked GREAT at the spring zing AX, especially with the OEM belt also used. No need to brace for corners. It was my first time using them. First time at a Solo II ax actually.
Deane
