Page 2 of 10 1 2 3 4 9 10
Originally posted by Keith Lennop:
My Bad!!
That's OK. Lot's of people around here running 17' wheels, too. laugh
As for this GB, I'll have to check with the boss to see if I can get an advance on my toy allowance. If I can't make the group buy, I would certainly be interested in a $600 kit somewhere down the road, perhaps next year.
FYI, for those of us still on the Queen's system, drop appears to be about 1.6 inches. IIRC, the ST200 was about an inch lower than stock, according to the press releases/articles I saw (and if I'm thinking of the right car) so Terry's statement would put total drop at about 1.8 inches, but this is all pretty much a WAG.
My last question is this: Are these progressive or linear rate springs?
"Function before fashion."
'96 Contour SE
1.8" drop! That seems pretty steep. Oh well, just another reason why the g/f can't drive the car wink
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
Sound by Crystal Mobile
Powered by a/d/s M860 AMP
My Ride
After finding the website,
(Larkspeed), it looks like 40mm (1.6") may be the more accurate number. My memory of the factory drop on the ST200 is probably wrong, or was reported imprecisely.
Even 1.6" is more than I thought I wanted, but for a matched set built on a Koni foundation, at this price, I am willing to seriously consider it.
'96 Contour SE
From http://www.racecar.co.uk/koni/flashmain.htm
KONI Sports Suspension Kits
Each kit contains front and rear adjustable sports shock absorbers
with matching Vogtland lowered coil springs. Individually designed
and tailored, they lower the vehicle by several centimetres and give
a firmer ride to obtain the best handling. Each Kit now comes
complete with a set of bump stops.
Vogtland Web Site, "Red Violet" Springs
'96 Contour SE
Hello, I was in the last group buy that Terry had so I might as well be in this one to. Just one question...How low is this going to make my car?? (Inches)
Thanks,
Justin
95 Ford Contour SE
71,000 Miles
Mods:
KVR Drilled Brakes
Aussie Bar...Thanks Terry!
Sparco Strut Tower Bar
Alpine CDA-7892 Receiver
Alpine CHA-1214 12-Disc Changer
Dual Polk Audio DX 10 Subs
Bazooka EL8A-hp
Oh yes...There's more to come!!
I'm definatly interested. I really need a new suspension but I will have to figure out how to come up with the cash.
So put me down as a maybe. Wish I could have a more definate answer, sorry.
Just curious why these are so much cheaper than regular Koni's? I wonder how aggresive they are compared to the BAT kit? And these are a matched set correct, which will cut down on the bounciness of other setups.
Thanks
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
The drop on an ST200 is 20mm,the drop on a stoc Mondeo is 40mm,Koni use springs from Vogtland (Germany) or Roc (Sweden) depending who has stoc...prices for batches of 5/10 etc to follow later...TH
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
Interested. Are the springs progressive or linear? Koni yellows?
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
I think they are the Koni reds, at least that is what the link went to on this page, however on the suspension page they look like they are yellows, so I am not sure?? I am interested either way.
99 SVT Green/Tan #44
TH-Fix, Aussie Pipe, PRO-M, SHO-Shop Y, Borla, and other Misc.
93 Tracer LTS
Eibach, K&N, Misc (now my winter beater)
email me: keith@thinkingcapdesign.com
My Car:
http://www.thinkingcapdesign.com/KeithsSVT/
Reds & progressive....
V6 MTX
Moderated by  1314_dup1
