Posts: 667 |
Dremel work may be necessary in any case and so the reason I suggest it, that way no one tells me later, 'Why doesn't it match up to my UIM!' I agree on the spacer deal, and I'll request for it! I hope you don't sit on it long, you may forget you left it under there
Posts: 1,201 |
There is some dremeling needed but not to the UIM. The TB gasket has a small bump that hangs down into the air flow. I took it out put it in a vise and used a file on mine. It does make a difference.
If it's true that we are here to help others, then what exactly are the others here for?
Posts: 667 |
Originally posted by Kaiser.: There is some dremeling needed but not to the UIM. The TB gasket has a small bump that hangs down into the air flow. I took it out put it in a vise and used a file on mine. It does make a difference. Thanks Kaiser! The gaskets will be made to match so there's no need to worry about the gasket...In any case the SVT manifolds were Extrude Honed and so the process has a tendency to fluctuate and not be always the same, so while yours may fit, another may have some lipage, it's just something I put in there as a precaution
Posts: 118 |
If either will work on a Zetec, I'm in. BTW, this group buy stuff is killing me. I just can't pass up an opportunity like this. I'm never going to get my credit card paid off. I'm actaully thinking of working weekends to pay everything off.
96 Contour GL (2.0L Zetec, ATX)
Sony CDX-C780 HU, Sony CDX-805 10 disc Changer, Sony XDP-210EQ, RF Punch 100.2 Amp, RF Punch 240.4 Amp, Dual 12'' Punch subs, Four Infinity Kappa 693.3i 6x9's, Optima Yellow Top
CTA Intake, Hood Struts, EL Ford Logo, Hi Beam/Low Beam Mod, Blue LEDs in door handles and footwells
Posts: 667 |
I'm not sure, I haven't looked at a 2.0
Posts: 118 |
It's worth $210-230 if you find out!
Posts: 372 |
Originally posted by ButtonPuncher 1.0b: [QB]If either will work on a Zetec, I'm in.
/QB] Don't think it will fit, location and cables are different .. check out Focaljet, they have some contacts and I saw a very nice Zetec TB about two weeks ago in Fresno, CA .. I can track it down for you if you wish .. jj
Posts: 667 |
Originally posted by ButtonPuncher 1.0b: It's worth $210-230 if you find out! OOOOHHH  , I tell you what, I'll send a roll of DuctTape with the TB that should help you secure it down Let JJ find out for you, there might be one out already
Posts: 5,296 |
Will I get the $40 back if this project is no go?
Posts: 667 |
Originally posted by AirKnight: Will I get the $40 back if this project is no go? Of Course!
