Page 5 of 6 1 2 3 4 5 6
2
2
Sorry Micah, but I have a few questions regarding the all CF hood since I don't know **** about CF, except that it is lightweight and looks sharp.
*Will the CF hood crack or bend over time? If I slam(not that I would) the hood shut, could it break?
*Are there any special things I will have to do after I get the hood? Is it O.K. to wax/clearcoat, or is there even a need to do so?
*Will I be able to use the stock hood prop? Could I use gas lifters?
*Will it look like a lot of the CF dash kits/pedals/shifters (the woven deep look)? Will it be polished?
Sorry again Micah, but for $650 I want to know what I am getting into(not saying it's not high quality, just curious). laugh I still have to think about it, as it would be purely for looks, not weight reduction(SE ATX :rolleyes: ).
2000 SE Sport V6
Deep Navy CC Metallic
My 2G Sport
Carbon fiber can't be painted over right?
I MIGHT be interested in a fiberglass hood...of course if it comes with a scoop molded in. I could tell you yes or no if there were some definite prices. I want to get a scoop molded into my hood...accounting for labor and new paint, the cost might be the same or only a little less than a fiberglass hood with the scoop already in it, so maybe I can kill 2 birds with oen stone - get the scoop and save some weight. Sorry to be a fence rider, keep up the good work Micah!
1999 Silver Frost SVT
#609 of 2760
Born on 12/3/98
KKM Intake
Removed Resonator
35% Window Tint all around
Tinted Tail Lights
ElKy Mesh Grilles
HID
Dyno'ed at 175.3HP/155.5TQ
Micah Offline OP
Originally posted by 2G Sport:
[QB]
[QB]
No, these carbon hoods would be stronger then the stock hoods. I dont see it cracking, of course if a car hit you maybe it would, but normal days use (open, shuting sitting in the sun. so on) it will last up just like your stock hood
[QOUTE]
[QB]
[QB][/QUOTE]
Good question. I dont know if there would be a need to, but I am sure you could if you wanted too. there is no prep work needed just bolt on and leave
[QOUTE]
[QB]
[QB][/QUOTE]
Yes to all of above.
Hope this helps you.
Micah
97 Lx 3.0 MTX
lighten flywheel,udp's,kkm,no cat,true dual,svt tb,80mm maf,19lb injectors,S-afc,svt ground effects, 18's w/ yoko 215/40/18,front/rear strut braces,eibachs,egr gasket mod,
15.2@94 with 2 people in the car and a bad 1st gear wanna race?
micah_trudell@hotmail.com
Originally posted by Gabriel Olivera:
I would like carbon fiber hoods to be an option, but I dont want the $650 to be the final price. Is that concrete? If we were to gather a much larger group, could the costs be cut drastically?
i sure hope it isnt concrete, cause then we'd see absolutely no weight savings laugh
97 Zetec MTX Sport
Esslinger UDP; Nology HotWires and BERU Silverstones; Sylvania Silverstars (high beam in low beam)
Dual Fiamm air horns
Mk1 Mondeo Clear corners(and yes I made them fit....)
Boston FS80's in the front
Micah's PRE98 SVT front bumper, W/ Mirko splitter(yet to be painted)
Rally drivers do it sideways......
Email: Roknut@linkline.com
AIM: AphexTwinGrin
Ash Offline
So micah when can we purchase? Just wanted to know? How long yet? Sorry for being impatient.
98 sliver frost SVT
now w/100,000+
OK.... One more hand in the pot......
I don't see the idea behind a stock hood design.
It is so damn hot under the hood, there should be some vents near the rear of the hood. Kind of like the rectangular vents on the predator hod, but put them across the rear of the hood. Nothing to extreme, but a subtle look, and a definate cure for the heat problem. Possibly a little raised (cowl) to lift the rear part of the hood..
Stock, but make the middle bubble up a little higher... We need to get the heat OUT!!!
I would love to get one, but other than weight savings, it's not worth it in my opinion.
Marc
1998.5 SVT
Micah Offline OP
Marc
Thats why I am making it with 2 options, stock and stock with air dam I will show pics soon.
Micah
97 Lx 3.0 MTX
I know very little about auto painting.
1. Is CF a good material to paint? How much extra prep time would be involved to sand down that glossy surface?
2. Fiberglass is very paintable I assume? Would I see ANY texture behind it, or would it be just as smoothe as the stock hood?
Brian Dors
99 SVT
OK Micah... Thanks for the update...
Just don't put no big ass scoop on it... Just some subbtle vents would suffice..
1998.5 SVT
Micah Offline OP
ok how many people will be able to get this hood next month if it is avaible? I will make the hood once I get 10 buyers and about 5-10 within the year.
Micah
97 Lx 3.0 MTX
Moderated by  1314_dup1
