Posts: 1,812 |
Ok, I asked Jack at Musclemotors.com about a group buy, and here's what he said:
"If we do a minimum of 5 orders I can sell them to you guys for $179 shipped to your door. All I need to know is injector size and if you have a cold air kit, NOS or Supercharger."
PM me if you want in. I'm #1 on the list.
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
Posts: 667 |
Ok Derk, it's clear the CnL works, as Warmonger has already informed me that he has noticed a difference, the only problem is the stuttering he is getting on that 3.o (not due to MAF)that won't allow for a full report. The thing with CnL is they back up there power gains with real world in house dynoing and comparisons with ProM on same Dyno, and it's been proven there MAF makes more power. Although they have not done to my knowledge any testing on our cars, if you've got #19 injectors or larger on your Ford Vehicle it'll work. I will check to see the best Sampling Tube that'll work with our cars, I think it's the Black One. If you folks want I will offer the CnL for $167.50 if 5 people buy, $160 if 10 buy, $152.50 if 15 buy and $145 if 20 buy. Of course you'll probably not reach the high #'s but I just thought I put it there since you really want to save every penny Just a side note: CnL 73mm is able to obtain 700cfm of airflow compared to the stock which is about 550cfm
Posts: 4,476 |
would be nice to see expected gains from this part.... 1-2hp or 5-10hp? etc...
Todd Christ SVT Contour Registry MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator '98 E0 SVT Contour #1037 of 6535
Posts: 945 |
so what is the GB here?
The pro-m or the cnl? Or is both going on?
joshua_drew@hotmail.com AIM "nerdsalot2" ************************* 1998.5 Black Contour SVT 1998 ZJ Limited 4.0L AWD
Posts: 1,812 |
Toadster - I'll be dynoing soon (see sig  ) and I'll probably put the MAF in while I'm on the dyno to see the gains. SVT98.5 - SilvaBullit is doing a GB on C&L (and ProM??) MAFs. I'm organizing a GB through musclemotors.com on ProM.
Posts: 460 |
I just got off the phone with Granatelli. I called them because I was concerned with the prices that MuscleMotors is selling their Pro-Flows for, considering that the price they are selling them for is lest than my cost from Granatelli as a Distributor. The rep from Granatelli said that MuscleMotors buys direct from BestProducts (the manufacturer of the MAFs) and that is why they can sell the MAFs for so cheap. Hell, I my as well just buy my MAFs from MuscleMotors then instead of buying from Granatelli....
Nikolas
1999 Mercury Cougar V6 KKM Intake,SVT TB, SVT Upper/Lower, 19lb injectors, Diablo Chip, MSDS Headers, Custom Exhaust, B&M Short Shifter, Progress Lowering Springs, 18" Axis TC's, OMP Strut Bar, AAM 24mm Rear Sway Bar, Koni Struts
15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
Posts: 667 |
Derk the ProM has shown that in most cases the Tour' benefits! The thing is I also operate a business and just trying to make people aware of the CnL option. The main reason the CnL hasn't been used is becasue the ProM was origianlly used and was given recognition on this site so people have been using it with mostly positive results. No body has been aware of CnL, I'm just making it known. The clear fact is by independent test the 73mm CnL reacted better than the (in comparison) 77mm ProM Bullet MAF (not 75mm) on a number of Mustangs, both stock and modified. I will be getting the CnL soon, if some of you are curious about the CnL option you may want to hold out a bit till I can give a report...... Remember a GB on the CnL can be a lot cheaper than the ProM!!! Aloha, Ioane Micah
Posts: 667 |
Also guys if you folks don't mind coughing up an extra $6, I'm willing to sell the ProM for $185 shipped to your door. At least you'll know you'll always see me on the boards
Posts: 945 |
Originally posted by Derk2000: SilvaBullit is doing a GB on C&L (and ProM??) MAFs. I'm organizing a GB through musclemotors.com on ProM. Thanks..I have to see if I can get some cash for one of these..I will let you or SB know..
Posts: 1,812 |
Micah, I am interested in seeing the C&L on the 'tour. I agree, the ProM has a good rep on these board and on our cars, the C&L may just need some recognition.
