Page 13 of 16 1 2 11 12 13 14 15 16
Got mine too. Thanks again to 1HOTWHIP!
'00 CSVT #570 - 3L
Got mine this AM. Thanks HOTWHIP and Ollie!
EDIT: Is there a How-To with pics around? All the ones I read had pics no longer available.
I installed them tonight and can't get the hood to stay even with the fender (the hood bulges up). confused
TIA
- Pete - 00 SVT SF/MB - 1522/2150 - DOB 1/12/00
92% says your group-NOT HOT
85% says your either wrong or BLIND
Blackhawk Down did NOT suck
you know who you are.....
I'm still waiting.....
for my bonnett supports...
waiting for the delivery man....
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
1
1
TIA
I'll post pics of mine tomorrow to help you out. I think that I posted the how to link earlier in this tread. As for rusting... I've had no problems with it yet.
Silver Frost 2000 SVT #1443 of 2150
Mirror Tint/ Momo shift knob/ Kurtz Kustom pedals
Ventshield raingaurds, moonroof and hood bug deflectors
True Rev Induction Kit/ BAT Air Inlet Pipe
Philips HID kit/ PIAA superwhite fogs/ Chrome Gas Bonnet Lifters
Top of line Alpine system( NVE-N851A, DVA-5205, IVA-C800, TUE-T011A, KCE-150V, CHA-S624, PRA-H400), PPI (PC 4100, PC 2150,PRO 10's), Image Dynamics CD2 Comp MH and IDQ-62.
Motorola Timeport HF car kit
Looking to increase performance!
http://photos.yahoo.com/hpick1
Future Mods waiting to be put on:
Lotek Guage Pod w/ volt, a/f ratio, and oil pressue.
Blue neon undercar kit
Aussie Bar w/ upgraded backing plate
Bullitt Fuel Door
Magnacore Wires
Ground Control Kit w/ Koni Struts
I got mine yesterday! All the pics from the write-up are gone? Anyone have some pics and a write-up on this? The other thread has conflicting info. Any help would be appreciated!
1998.5 Toredor Red SVT Contour
1998 Triple Black SVT Cobra Vert
www.cobraunit.corral.net
E
E
frown
my credit card hasn't even been charged yet!
frown
**HELP SAVE CEG!!! DONATE NOW!!!**
*This space for rent*
Please call...
1-800-FOR-ELKY
All proceeds go towards saving CEG
Installation Instructions:
The struts will bolt-in using EXISTING bolt holes, ie, NO MOD. IS REQ'D!
The correct hole to use in the hood, is the hole NEAREST the windshield (hood in closed position).
The correct fender bolt hole to use is the hole that is nearly inline w/ the radiator water fill cap, ie, the hole just past the rectangular opening, towards the windshield.
Install was a breeze, tighten the hood bolt that remains in, and remove te lower ones and insert the non-self-tapping screw in that hole. Remove the bolt from the fender, and insert the self tapping screw, making sure to use washers in both locations. Pop the end pieces on, and insert the clip.
The hood stays open great, they are not quite strong enough to open the hood w/out human help, but once open they do stay just fine. Closing is quite simple, just push down gently on the hood and guide it wo where you usually drop it to engage the hinge.
I also removed all the writing on them with some Chrome polish and some fine steel wool.
So where does the clip go? I just finished putting mine on and I didn't see where it would fit. though they might go in the socket but there was already a clip in there and the ends of the struts snapped into the sockets without any problem.
If you look at the end caps, you will see a tiny hole, the straight part slides through that hole, and the curve hooks around under the socket. It works as a locking mechanism, won't come off with those installed. I didn't use the nut, I suppose you could get it in behind the bolt on the hood itself, but what a Pain in the Arse.
One thing I have not read here is... on the driver's side there are cables running underneath the fender lip, the original bolt has a rubber cap. Make sure you use it. Helps to prevent piercing the cables. smile
Edit: Photos of bonnet lifters on my car.
Got them! laugh Thanks to 1HOTWHIP for making it happen!
Moe Offline
got mine too, thanks again! smile
-- Mike (Moe)Lester --
98.5 SVT #5486
moesvt@comcast.net
Get your a$$ on IM and stop wasting bandwidth!!!!!!
Got Mine and put them on. A snap! Thanks very much!
98.5 SVT, Vortech SC, Bassani, Quaiffe, Clutchmasters Stg. 3, BAT Sport Springs/Konis, 17" Momo Arrows, Sparco Brace,BAT 22mm Sway Bar, PIAA fogs & headlights.
Moderated by  1314_dup1
