Posts: 1,445 |
mmmmmmmmmmmmm.....turrrrrrrbooooooo i think i need a cold shower now all i need is for about 6-8k to fall from the sky for a 3.ho duratec the turbo and maybe my transmission if the warranty people dick me over
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!! are my dodgers for real????
Posts: 744 |
can we go front mount, or is it already?
Black 99 SVT Ground Control Coilovers 19" KMC Tensions (Gunmetal)
Silver 98 SVT Ground Control Coilovers 19" KMC Suicides (Flat Black)
Posts: 4,476 |
this would be the perfect post to have a :Sticky: application so it stays at the top of the charts in Off Topic...
Congrats on the development, not in my budget - but for those of you who have a Tax Return burnin a hole in your pocket - GO FOR IT!!!
Todd Christ SVT Contour Registry MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator '98 E0 SVT Contour #1037 of 6535
Administrator
Administrator
Posts: 5,037 |
Originally posted by brent: can we go front mount, or is it already? Water/air. It will be in the engine bay, and the water radiator will be up front. Air/air involves quite a bit of piping, which there isn't much room for. -Chris
Posts: 2,848 |
Options needed to complete kit(some people already have these components) -High flow air filter (KKM will not work) -Apexi S-AFC fuel computer -High flow catback exhaust (stock resonator will not be allowed)
Are these required?? That would all put the cost closer to 6k
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Administrator
Administrator
Posts: 5,037 |
Originally posted by TheGreatOne:
Are these required?? That would all put the cost closer to 6k Those components are included in the $4500. If you already have them, you don't have to buy them again. So, that makes the kit cheaper. EDITED now to reflect this. Good question -Chris
Posts: 7,329 |
Not that I can afford it, but... DAMN!!! I am jealous!!! I give you full props for pulling this together Chris. Can't wait to see the numbers! Bet you'll have to beef up that poor ATX a bunch...
Posts: 107 |
~nick 2001 Cougar V6 MTX KKM, C&L MAF, SVT TB, SVT UIM, SVT Injectors, B&M Short Shifter, Gutted Precats (yawn), Bassani Exhaust, SVT Front and rear Engine mounts, Energy Suspension engine mount inserts, Quaife Differential, Fidanza Flywheel, Grizzly Clutch. OMP Front STB, Custom Rear STB. Various cosmetic and stereo mods.
Posts: 1,152 |
Chris, What will the typical install cost of this whole kit? Those Hp numbers are at the crank? Thanks, Joe
1998.5 T-RED SVT 18" Team Loco 142's W/ Dunlop Rubber 181.2hp@6900rpm/155tq@5000rpm LOTS OF MODS OF EVERY KIND.... ...Am I a guru yet??? No... not yet.
Posts: 1,496 |
Originally posted by SVTJOE1: Chris, What will the typical install cost of this whole kit? Those Hp numbers are at the crank? Thanks, Joe Ditto. Install costs (at least a ballpark estimate) will be greatly appreciated. $5k is getting close to my "scrooge" scenario for ANY upgrade on an asset that depreciates faster than lead sinks in water... VERY interested in this.
JaTo Overland Park, KS JaTo@kc.rr.com
99 Contour SVT #143/2760 Modded to Taste
00 Corvette Coupe Modded to Haste
