Page 9 of 14 1 2 7 8 9 10 11 13 14
leo Offline
well i will be moving to wa in march any one no the laws there as far as the turbo goes?
i am not to worried about it just would be nice.
99' contour sport
atx,new pedals and mesh grill, 98 TSW Zenon 17x7 225/45/17 toyo proxes, svt front brakes,svt springs and struts,sho shop y-pipe no cat, and sho shop
adapter for k&n cone air filter, sca 2 1/2" piping into two can styled magnaflows.
http://communities.msn.com/DeviousContour/contour.msnw
Administrator
Administrator
bumpo
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
H
H
chris, is there any concern that our engines won't be able to handle all the extra power. u said 300hp is being conservative. assuming we do the standard upgrades...clutch, flywheel, lsd, exhaust, suspension. will the engine internals hold up over time.
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Administrator
Administrator
Bottom end is the weakest link on the engine. It should handle the extra power just fine with proper oil changes, and proper amount. Once you go above the power the kit will provide you're pushing the limits of the engine. We are mainly concerned with the safety of the engine.
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
Any info on what your "upgraded" tubo kit will be, or the numbers you shoting for, or is this still a long way off??
99 Ford Contour SE Sport
Manual V6
SVT front/ rear bumper /w Aussie grille
Jet black
Premier DEH-P740MP head unit
matrix display, plays Mp3s!!
800 watt Kenwood amp
2 12" Polk Audio subs
Blue "euro" headlights
Eibach Pro-Kit springs
17" Enkei RS-5
White Indiglow gages
Chris actually the rods will be your weakest link. changing out the rods will increase the engines Durability so much more.
By the way Chris how are they determining whats the power limit of the 2.5? And what is that limit and what does it suggest? thanks
wink
Performance Xpress Racing
Silverbulitt@msn.com
Our websit www.PXRacing.com is coming soon!!
We carry Contour/Cougar parts for the 2.5 Duratech and 2.0 Zetec
Administrator
Administrator
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
Chris,
Thanks for your hard work on this project. It's great to see someone expanding the performance of our cars.
I'd like to throw in my $0.02 on why I'm not getting into this buy; perhaps it will help you understand where some of us are coming from, though I may be in a tiny minority.
I look at my car as a BMW 3 Series fighter. Or a sharper, leaner, baby Lincoln LS. I don't care what the supercharged Eclipse or coffee-can exhaust Accord next to me can do. I want speed... with elegance and calm.
As such, I'm not willing to give up my stock intake and exhaust. If you sold an entry-level version of the kit, that was low-boost and, say, 260hp @ crank, I could run stock plumbing and the car would retain most of its serenity.
This would also negate the absolute need for a lsd, a racing clutch, etc.; if you just show a little restraint in first gear.
A little turbo whine I could live with. On top of that, adding a louder intake, and a rumblier exhaust... sorry. I've already put a couple hundred bucks of dynamat into the car (which probably added a lot of weight too, but it's worth it to me).
Anyways, this isn't a criticism of your project. I realize I'm in the minority on this position, most people on here probably want to see the absolute highest level of psi possible.
I just thought I'd explain where I'm coming from.
Thanks....
Brian Dors
1999 SVT
Administrator
Administrator
Brian,
Thanks for the input, but I'm not really seeing the point of it on this thread. I can understand not wanting to mod a car like the Contour to this degree. There is no need to explain why you're NOT getting the turbo kit. Silence and absence of deposit money will do laugh
-Chris
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
Reason for the post: I guess in the back of my mind, I was hoping there would be an easy way to modify the turbo to work on a stock vehicle.
Not being a turbo expert I didn't think this through very carefully; after some more consideration on how turbos work, I can see that one design wouldn't fit various setups. It's not just a matter of lowering the boost like I thought at first.
Best of luck.... I hope to some day get walked by a turbo SVT. And I'll be smiling and cheering him on.
wink
Brian Dors
1999 SVT
Moderated by  1314_dup1
