Page 7 of 22 1 2 5 6 7 8 9 21 22
Okay I in, would look good on my ZX3.
what do I do now?
I'll buy one at the end of this week
Infinity 6 1/2 in. speakers in all doors
2 10in. Kenwood Tornado Subs
Logic Soundlabs 840 watt amp
my car would be sweet if the cops didnt take all my money
Personally I'm ready to just fork out the 5 bucks and get the ordering going. Mani, what do you think?? I just wonder if everyone that said they were in on this are still feeling this way.
hook me up
1996 Ford Contour GL
K&N FilterCharger
Changed most interior lights to blue
Installed Xenons in high/low beams
GTS Blackout Headlight Covers
FLOWMASTER Series 3
NGK Sparkplugs
WindowShield Washer Lights
No Rez
Custom Intake
Clifford Sabre 2 Alarm System
Removed Ding Guards
Mani Offline OP
Awesome we got 15 as of now ...
J-Rod if its OK with everyone else I really don't have any problem at all laugh But I would think we would get 5 more people real soon ...
So everyone thats in the group buy if you can just post if you would want to pay the extra $5 and start with the ordering let us know smile
Is this still going? If so id like in...
Id also like a picture... thx.
Mani email me please....mark@modernkreations.com
thx,
-Madcow- from the Jet
Alright, I'm in for one too. What does this bring the total up to? 17? I'd prefer the $55.00 price obviously, but I'm in either way. wink
blk.99svt
n.e.Ohio
Never under estimate the power of stupid people in large groups...
Madcow, I posted a install guide and a few picts over in the FocalJet thread for ya wink
Mani, there is a possibility that we can get a few more from FJ over here. I'm working on it.
Mani, Sign me up!
Here is a post I put out after installing mine. I think you will find it helpful.
Instructions for installing the Mustang aluminum fuel door without body damage and retaining fuel door assembly
1. Open the fuel door
2. Remove the gas cap
3. Remove 8mm gas cap tether screw
3. Rotate fuel door assembly CCW 30 degrees and remove disconnecting rubber hose
4. Remove the fuel door from the assembly
a. Split the small housing that has the rubber hose connection by prying the perimeter loose with pliers
b. Insert a screwdriver between the two pieces and pry them apart
c. Stick a screwdriver in to the door's pivot point and spread the assembly so it releases the door
5. Glue the two pieces back together
6. Remove all of the mounting screws from the new fuel cover mounting ring
7. Using a grinder or file remove the two raised areas on the back of the new mounting ring where the long screws were. The back of the new mounting ring should be smooth.
8. On the face of the existing fuel door assembly, right where the rubber gasket ends there is a small raised lip. This must be trimmed away to allow the new mounting ring to set flush on the rubber gasket.
9. Align the new fuel door on the old fuel door assembly so that the hinge is on the right side, same as the old one. Temporarily reinstall the fuel assembly maybe a good idea at this time to be sure you get the new door on straight.
10. Drill small pilot holes thought the old assembly using the new fuel door ring as a template. Remove the assemble from the car.
11. Drill the top and bottom mounting holes with a bit large enough to allow the long screws to go all the way through.
12. Insert long screws into these holes and add two washer spacers to each with a nut. The washers will need to be trimmed on both sides to allow them to fit down close to the hole in the assembly.
13. Drill the remaining hole just large enough to screw the remaining short screws in the plastic assembly.
Some glue should be added to these to hold them in. Two of the holes will line-up with the mounting tabs of the assembly, do not be drilled through the tabs.
14. Reattach rubber hose and reinstall fuel door assembly clock wise with new the aluminum door attached.
15. Reinstall the fuel cap tether screw and your done. laugh
-Bill D.-
1998 Silver SVT #862
Mods: MOMO Racers 7.5x17, 17X215/45 Potenza RE730, Color matched GTS Headlight Covers, OPM Strut Bar, K&N Filter, Hood Lifts, Eibach Springs, Alpine CDA-7875 w/4 Polk EX & 2 Jensen Tweeters, B&M Short Shifter, Bullitt Aluminum Fuel Door, Billet Aluminum Control Knobs and SVT Lighter, Aluminim E Brake Handle, Borla Exhaust, SHO Y-pipe, Aussie Bar, Splitter (ready to install), Indiglo Instruments
Moderated by  1314_dup1
