Page 4 of 9 1 2 3 4 5 6 7 8 9
Oh I see Well in that case how much for the SVR80?
Sorry I missunderstood you smile .
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
The SVR80 roughly is $120 (dont have exact price in front of me at this time)plus shipping (its a beast, about 50+ pounds) You may want to look into the Interstate Spiracell battery (made by Optima for Interstate) I think I can get those a bit cheaper, but I think one of the major part stores had it for $129 (would be close to same with shipping) Also ebay always has yellow/red tops up for around $105.
Do you think this is a good start to put an end to the dimming lights syndrome wink
I figure its about time for a new battery and its probably a good place to start. That and new connectors.
if you can email me with a specific price I may get the SVR battery. Well that is if I can't find anything else similar locally. (Save some cash on shipping)
Thanks
Justin
1998 Black SVT
have you upgraded the factory ground under your hood? thats the first thing to do. If you have a voltmeter check your voltage make sure it is staying pretty steady (+/- .5v is normal with a large amp, but is should not be more than that with a good install)
Ok thanks for the tip. I'll try and do that when I get some time. There is still so much I want to do Car Audio wise, and performance wise to my car.
I just don't seem to have the time or space to do it wink
I'll let you know when I decide to get the battery. I do think I need a new battery since my car is taking a bit longer to crank lately.
Justin
1998 Black SVT
knu...do you have a splice pice to fit two or more caps together if i wanted?
second question would be...when you say bigger ground what do you mean?
pauli18@aol.com for questions
99 green svt
asp udp
b-n-m short throw
kkm intake
n the list grows steadily
If you have a 4ga powerwire from your battery to amps in the trunk and a 4ga ground in the trunk to amps, whats at the battery? Your factory 8/10ga ground. Power starts at the battery (on the ground side technically), adding 4ga in the trunk is useless if it has to pass through 8ga first. It does make a difference.
ok thanks...than i wana buy from you some 4awg n what ever else i need to do the bigger ground....lemme know
pauli18@aol.com
99 green svt
asp udp
b-n-m short throw
kkm intake
More cash
Payments received:
Tricked96
Blitz
Elky (x2)
Dion
Kirill
Still have a few more days to get payments in on this buy, you wont see this price on a New Digital cap again
yeah you cant go wrong on this one guys.....its a steal if you ever plan on getting one....believe me a 200$ cap versus a 60$ cap works the exact same!!!!
99 green svt
asp udp
b-n-m short throw
kkm intake
Moderated by  1314_dup1
