Page 1 of 6 1 2 3 4 5 6
Z
zxtuner Offline OP
Z
Hey Y'all,
Got a killer deal for you - New (not takeoffs) OEM Focus SVT wheels from Ford Racing at $139 each! I need to deliver a 16 wheel (4 sets) order to secure this pricing.
Specs:
17 x 7"
4 x 108mm bolt pattern
appearance - what is used on the 2002 Focus SVT. The WILL bolt up to Contours and Cougars. The look nearly identical to the 98.5-00 Contour SVT wheel, except they are a 17" rim. They are silver painted, with a black center cap containing the SVT logo.
Any interest? Please email me at zxtuner@hotmail.com . I'd like to get this first order in before Dec 7, so it'll be possible to have these dished up to you all by Christmas!
Rob
ZXtuner Store
1999 ZX2 S/R
139.3 wheel hp @ 6900 rpm
9.62 sec @ 72.11mph (1/8)
2310 lbs.
Do you have a weight on these? Is the offset correct (what is it)? Thanks.
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
SVT Offline
Can you post a pic of the actual wheel?
Ryan
Toreador Red
1998 SVT #2843
"Performance in the hands of few"
Z
zxtuner Offline OP
Z
I'll scan a page out of the Ford Racing book when I get to my office on Monday.
I'll have to call too to get the exact offset and weight, but I believe if it's like the other factory Focus wheels it's in the 45-50mm range, and weight is probably around 18-20lbs (OEM wheels are never very light, because they're usually made to withstand a high level of abuse, even in a 5 spoke variety like this).
Rob
ZXtuner Store
1999 ZX2 S/R
2310 lbs.
108mm x 4 is the offset, all focuses, tempos and contours have this offset, bar none.
95 SE Champagne Mettalic
True Dual exhaust with X pipe and Redline mufflers
KKM Tru Rev intake
H&R Springs/KYB struts
Apex-i S-AFC
65mm Throttle Body
17" Ace Spades
4 Pt Racing Harness
Window Tint all around
New Engine @ 117k kilometers
G-Tech: 15.6 @ 91.5 MPH
"you officially kick ass"
quote from awed CEG'er after i chopped my hood and threw on scoops
RIP 98 SVT silverfrost *nov 4 2001*
Master P
Master P
108 x 4 = 432. That's a bit too much, don't ya think?
Z
zxtuner Offline OP
Z
haha - right intention, wrong figure.
4x108mm is the bolt pattern, offset refers to how much additional rim width from the centerline (face of rim that touches brake rotor)... positive offset sticks more rim out past the rotor, negative offset sucks the wheel rim in toward the brakes (I hope I don't have this backwards)
FWD cars have a negative offset, usually around 35-40mm. Contours and Focii run a larger amount of offset, in the 40-50mm range.
Rob
P.S. Perry, I havent forgot about the zetec contour intake - the custom filter arrived thursday (one that's the right diameter to fit directly onto the MAF).
ZXtuner Store
1999 ZX2 S/R
2310 lbs.
depends on the unit of measurement. Remember that he is from Canada. After the U/M conversion, it is only worth 6.
W
W
I'm interested, but I don't understand the offset thing after reading the post. I thought that offset was the diagonal distance between the bolt lugs. There may be another offset for that other stuff, but 4x108 is four lugs that are 108mm diagonal distance. 1"=25.4mm so 108mm=4.25" which is the same I believe as the contour.
What tires are coming OEM on the Focus?
I only want these rims if they look the same as the E1 rims.
warmonger
You can call me anything you like as long as it's nice.(all lies accepted)
99 Silver Frost SVT. #226 of 2760
Engine: 3.0 power!
Unique Stuff: Sunroof control module (#1 of 9)
Car Audio: Loaded and loud!
Check them out at
http://home.earthlink.net/~twilson1726
W
W
Why are you multiplying these together?
This is the same kind of notation used in the term "4x4 Truck"
warmonger
Engine: 3.0 power!
Check them out at
Moderated by  1314_dup1
