Page 3 of 3 1 2 3
Q
QWICSVT Offline OP
Q
Sorry Micah, but I must disagree. In the case of body parts, OEM is always better than aftermarket. Aftermarket body parts more often than not turn out to look like all the chessy body kits that kids install on their imports. It is simply a matter of production process refinement which is difficult to achieve at such a small level of output. Now this is my OPINION and you of course are entitled to yours, so lets leave it at that and not get into one of the pissing matches that this site is famous for.
98.5 SVT ~ diamond white metallic custom DuPount paint ~ shaved antenna, trunk key hole, and ding strips ~ roof mounted antenna ~ 20% tint ~ clear corners (front) ~ Audi A4 sidemarkers ~ 17" Mille Mille Evo 5 wheels with Yokahama Parada Spec-2 tires ~ Koni adj. struts ~ Eibach springs ~ SMA rear strut tower brace (front no longer fits ~ Powerstop cross-drilled rotors ~ Mintex A/F pads ~ ploy bushings including motor mount insert ~ 3L conversion ~ full custom intake ~ custom Cardoc exhaust ~ gutted precats ~ 24lb injectors ~ 3L upper and lower intakes ~ Rear dome light mod ~ glovebox light mod ~ lighted moon-roof switch mod ~ fog light mod ~ Autometer shift light ~ FCO indiglow guages ~ body color interior bits ~ some custom sound
Administrator www.fordcontour.org
In my post I dont remember saying anything about aftermarket is better. so let me clear this up for everyone. aftermarket isnt better, Plastic is better. how much better? thats up to the indivual. not the seller. all I was saying was the rear svt bumper that I will be making will not shatter or crack if it hits something, yes there is a breaking point just like any material and any bumper. is plastic woeth the extra money to get? up to the buyer. will it look like cheese. NO. it will look like a stock bumper, in fact it wont look like fiberglass just buy looking at it. only buy touch and feel of the backside would you realize it is fiberglass. By no means am I doing a pissing war, just trying to correct things you say that are not true, instead of being defensive do some research on the materials and then comment, it seems like the knowledge you have is from looking at $500 honda ground effects kits there is alot more to it then that.
Micah
97 Lx 3.0 MTX
lighten flywheel,udp's,kkm,no cat,true dual,svt tb,80mm maf,19lb injectors,S-afc,svt ground effects, 18's w/ yoko 215/40/18,front/rear strut braces,eibachs,egr gasket mod,
15.2@94 with 2 people in the car and a bad 1st gear wanna race?
micah_trudell@hotmail.com
Page 3 of 3 1 2 3
Moderated by  1314_dup1
