Posts: 277 |
"Plastic"...I need 15 orders to get that price for everyone. I could get you one now, but it would be a good deal more. See if you can drum up some interest. Please leave your email address next time.
98.5 SVT ~ diamond white metallic custom DuPount paint ~ shaved antenna, trunk key hole, and ding strips ~ roof mounted antenna ~ 20% tint ~ clear corners (front) ~ Audi A4 sidemarkers ~ 17" Mille Mille Evo 5 wheels with Yokahama Parada Spec-2 tires ~ Koni adj. struts ~ Eibach springs ~ SMA rear strut tower brace (front no longer fits ~ Powerstop cross-drilled rotors ~ Mintex A/F pads ~ ploy bushings including motor mount insert ~ 3L conversion ~ full custom intake ~ custom Cardoc exhaust ~ gutted precats ~ 24lb injectors ~ 3L upper and lower intakes ~ Rear dome light mod ~ glovebox light mod ~ lighted moon-roof switch mod ~ fog light mod ~ Autometer shift light ~ FCO indiglow guages ~ body color interior bits ~ some custom sound Administrator www.fordcontour.org
Posts: 26 |
Are these in good shape I really would like one.
Can you keep up? 99 SE Sport ATX K&N 18" OZ Superleggera and P7000 Door Guards removed and all badges removed Sony Head unit Two 12 W7 JL and a host of other small mods.
Posts: 277 |
OK, we have 7 maybes so far. As for waiting until spring, that will most likely not be possible. The order will need to go down within 2 months.
Posts: 433 |
Originally posted by QWICSVT: OK, we have 7 maybes so far. As for waiting until spring, that will most likely not be possible. The order will need to go down within 2 months. I'll be in with-in that time period. You should get a definite answer from me after I start my new job next month. Thanks.
Silver Frost 2000 SVT #1443 of 2150 Mirror Tint/ Momo shift knob/ Kurtz Kustom pedals Ventshield raingaurds, moonroof and hood bug deflectors True Rev Induction Kit/ BAT Air Inlet Pipe Philips HID kit/ PIAA superwhite fogs/ Chrome Gas Bonnet Lifters Top of line Alpine system( NVE-N851A, DVA-5205, IVA-C800, TUE-T011A, KCE-150V, CHA-S624, PRA-H400), PPI (PC 4100, PC 2150,PRO 10's), Image Dynamics CD2 Comp MH and IDQ-62. Motorola Timeport HF car kit Looking to increase performance! http://photos.yahoo.com/hpick1 Future Mods waiting to be put on: Lotek Guage Pod w/ volt, a/f ratio, and oil pressue. Blue neon undercar kit Aussie Bar w/ upgraded backing plate Bullitt Fuel Door Magnacore Wires Ground Control Kit w/ Koni Struts
Posts: 4,899 |
Hmmm well my car is electric red....GRRR must have it repainted....What do these cost new from the dealer? Anyone?
Posts: 61 |
I'm in. Time is not important, but the bumper is.
98 Mystique LS BLK V6 ATX and my bald head behind the wheel. mods so far: SVT Exhaust 215/60R15 Potenza RE950 Pioneer Premier DEH-P520 headunit with XM Radio BNMotorsports gauges KKM Intake SVT side skirts A pillar gauge pod with Volts, Oil Pressure. and A/F Ratio
Posts: 277 |
New cost: $822 and change.
Posts: 277 |
P.S. These bumpers are OEM material and not fiberglass which WILL crack the first time you hit a driveway curb or any other object for that matter.
Posts: 433 |
Originally posted by QWICSVT: New cost: $822 and change. What's the regular cost for this???
Posts: 1,022 |
"QWICSVT P.S. These bumpers are OEM material and not fiberglass which WILL crack the first time you hit a driveway curb or any other object for that matter. "
I am sorry to tell you this, But the only fiberglass bumpers that crack are the ones not made strong enough, the bumpers I make are strong enough, there isnt a worry about cracking. infact Plastic bumpers crack too. people get into 5mph accidents and boom, bumper crack. I think alot of people have seen cheap fiberglass work. Fiberglass is as strong as you make it. I dont know if you said that commment because of my groupbuy or just for the heck of it, but make sure you have your facts straight before you diss something you dont know. I will agree fiber glass will shatter or crack IF NOT MADE RIGHT or strong enough for the purpose of the bumper. But the ones I will be making are going to be strong enough.
Micah
97 Lx 3.0 MTX lighten flywheel,udp's,kkm,no cat,true dual,svt tb,80mm maf,19lb injectors,S-afc,svt ground effects, 18's w/ yoko 215/40/18,front/rear strut braces,eibachs,egr gasket mod,
15.2@94 with 2 people in the car and a bad 1st gear wanna race?
micah_trudell@hotmail.com
