Page 18 of 20 1 2 16 17 18 19 20
E
E
how long are they?
97 gsxr lotsa good stuff 4 sale
95 talon tsi awd turbo loaded sold
95 se 2.5 mtx loaded (fragile handle with care)2 motors 3 trannies
custom y with hi flo cat,custom dynomax exhaust,upper cat mod
superchip,udp,bat\kkm,proflow maf,ford 9mm wires,svt throttle body,svt intake manifold ,custom kevlar clutch,16 pd. flywheel,svt motor mounts ,svt gauges,eibachs\h&r,omp strut brace,dark chrome 16" rials with 225/50 dunlops,cwazy amounts of audio
jjh Offline
Originally posted by el contouro:
how long are they?
I got them today. They are 15-1/2" long
I'll try to take a look tonight if I can get them in
confused
jjh
2000 T-Red SVT
#2134 of 2150
jjh Offline
Originally posted by monkeyra:
what are you stuck on guys?
let me know and i'll help you out. I've got the same ones on mine.
Thanks! smile
I'm sure will have some questions tomorrow morning laugh
jjh
2000 T-Red SVT
#2134 of 2150
Sorry I have been away. Busy at work. I still haven't had time to try again. I see someone said something about removing fender bolts. I don't know if that is the problem or not. Anyone can call me to discuss. 616-437-2737
"If you're pushing crazy I'm all full up here."
{Black '96 Contour SE MTX w/ over 126k on the clock}
· Get the skinny here.
· Need a 96-00 Ford Service Manual on CDROM?
Yea....I'm just going on memory here. But I think I remember seeing like say 3 bolts on the bottom lip (Where the fender meets) 1 or more of those might need to be removed or replaced with a lower profile bolt.
Also make sure you attach the hood end of the strut to the top bolt. That way the struts will have enough leverage to keep the hood up.
I hope you can get them installed...Can't wait to get mine. I just don't see what would keep them from fitting other than those bolts. And again...this is all from memory, I'll have to take a look tomorrow smile
Good Luck!
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
jjh Offline
Last night I was checking fitting of the lifters, and I believe they are a bit too long. If you use the top bolt of the hood (when is open) and the bolt on the fender lining up with the coolant reservoir's cap you wont be able to make it close all the way. Now, there are two bolts by the coolant reservoir and in between there is a hole which could be used. Right now these are my observations. But if if comes down to having to drill a hole then so be it. Anyone else have any other ideas?
jjh
2000 T-Red SVT
#2134 of 2150
E
E
The supplied self tapping bolt is too small of a diamter for the center unoccupied hole and almost falls through, actually the washer almost does.
Once it is fitted though, the strut will compact a little bit, so I am not too worried about the length.
I'll take some pics tomorrow night.
2000 SVT Contour - Silver # 1675/2150
svt1675@comcast.net
This Shine brought to you by the letter "Z" for Zaino
Not quite following what you are saying their. Did you get the hood to close?
Got mine today!
I was thinking I wasnt going to get them.
Anyone have any luck getting them in?
Howard
1998 Silverfrost SVT #1612
June mods:
17" ADR RS Limited Limix Wheels
with 215/45/17 Yokohama AVS Sports
E
E
I didn't install them, I "surveyed" the area with MadMole's directions in hand and realized something wasn't right. I'm off to take pics now, be back in a few.
svt1675@comcast.net
Moderated by  1314_dup1
