Posts: 4,528 |
Posts: 1,421 |
i pulled a set of trunk struts outta my parts car.they r a lil over a foot long.how much bigger r those
97 gsxr lotsa good stuff 4 sale 95 talon tsi awd turbo loaded sold 95 se 2.5 mtx loaded (fragile handle with care)2 motors 3 trannies custom y with hi flo cat,custom dynomax exhaust,upper cat mod superchip,udp,bat\kkm,proflow maf,ford 9mm wires,svt throttle body,svt intake manifold ,custom kevlar clutch,16 pd. flywheel,svt motor mounts ,svt gauges,eibachs\h&r,omp strut brace,dark chrome 16" rials with 225/50 dunlops,cwazy amounts of audio
Posts: 111 |
Here's my piccy Easy to fix really, 10 mins tops
96 Mondeo 2.0 GLX 16v Zetec Ford 16" 12 spokes ABS 59000 miles
Posts: 2,847 |
Walked out to the mailbox just now, and guess what was popping its little head out!  Going to look at the instruction that were posted, then off to attempt an install. Todras, e-mail me as I'm interested in what to listen for letting me know when to quit.
Posts: 2,066 |
I'm haven't read what problems Todras had....but....I was under the impression we were going to have to take a couple bolts out so the struts will sit flush, as were on the Mondeo the bolts were not present.
Again I haven't read what Todras said and I don't have mine yet to look at..
Good luck, I hope we can figure something out!
Later
Posts: 2,847 |
Originally posted by todras: WARNING:I'm having fitment problems. Seems that the fender hole is closer. I bent the fender area a little. I'm looking into everything slowly. I'm not sure I want to close the hood all the way to test it. I should have stopped when I heard the paint cracking!JC, look up. Mainly at this post, but a few following go into more detail.
Posts: 2,847 |
Here is what you get (x2 of course). The color is chome, its just the lights, and the angle makes it appear bent. I have the approprite hardware in its places, but where do the 2 clips and the nut go? Todras, you have AOL IM? Mine is svt1675, look me up and we can chat before I attempt to install it.
Posts: 187 |
Eric give me a call on the MO side at 3731819 and I'll aswer your questions
-Bill D.- 1998 Silver SVT #862 Mods: MOMO Racers 7.5x17, 17X215/45 Potenza RE730, Color matched GTS Headlight Covers, OPM Strut Bar, K&N Filter, Hood Lifts, Eibach Springs, Alpine CDA-7875 w/4 Polk EX & 2 Jensen Tweeters, B&M Short Shifter, Bullitt Aluminum Fuel Door, Billet Aluminum Control Knobs and SVT Lighter, Aluminim E Brake Handle, Borla Exhaust, SHO Y-pipe, Aussie Bar, Splitter (ready to install), Indiglo Instruments
Posts: 111 |
Didnt anyone look at my photos then?
Posts: 1,002 |
what are you stuck on guys? let me know and i'll help you out. I've got the same ones on mine.
********************* WEBMASTER OF: www.fordmondeo.org ********************* Car I own: lightly modded mondeo ********************* Mondeo, Daddy of the Contour!
