My small pipe was bent about 5 degrees too few as well!!
I sat under the car for 2 hours trying to make it line up right to no avail. If I install the pipe so everything hangs correctly, then there is a leak on the front edge of the rear pipe. Adjusted so it has a good seal makes it hangs down like some bad ghetto patch job.
I have an appointment at the local muffler shop Monday 7:30am to take care of the bend and to have it welded up.
This is my second SHOShop product, and so far they rate about a 6.5 out of 10, not too bad for a small volume aftermarket parts maker.
Yes, the pipe was mailed to my work address- Thanks!!
