Posts: 4,476 |
the big box has a checklist with all the appropriate parts in that box, however my "little white box" came a day later with that single pipe flange (see my pic above) with no parts list....
hope that helps!
Todd Christ SVT Contour Registry MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator '98 E0 SVT Contour #1037 of 6535
Posts: 1,003 |
Arrived via FedEx this morning, everything intact. No white box for me! THANK YOU!!!!
Posts: 945 |
Got mine today!
joshua_drew@hotmail.com AIM "nerdsalot2" ************************* 1998.5 Black Contour SVT 1998 ZJ Limited 4.0L AWD
Posts: 1,732 |
Originally posted by Toadster: the big box has a checklist with all the appropriate parts in that box, however my "little white box" came a day later with that single pipe flange (see my pic above) with no parts list....
hope that helps! hhmmm...got the ss pipe, but no single pipe flange or white box. if i don't get mine by monday, i guess i'll be calling.... on a side note, this is the first time dealing with sho shop and i don't think i'll be doing much business with them anytime soon.
- Pete - 00 SVT SF/MB - 1522/2150 - DOB 1/12/00 ------------------------------ 92% says your group-NOT HOT 85% says your either wrong or BLIND Blackhawk Down did NOT suck you know who you are.....
Posts: 82 |
I was wondering bout the flange too.. Is there supposed to be two or three flanges?? (i lost the parts sheet after i installed the pipe) Cuz i also received another package with the single flange 3 days later. (if it turns out that there is only supposed to be 2 flanges, i can give the extra one i have to some one who needs it.. svt st pete?? or anyone else)
Also i'm not sure who else put their y-pipe on. But i'm experiencing exhaust leaks from the front pipes. Bad clamps?? thanks
merrick
Silver 98.5 SVT 5/19/98, 6023
Posts: 999 |
Originally posted by Bicycle019: Arrived via FedEx this morning, everything intact. No white box for me! THANK YOU!!!!  Did it go to your work office?
14.72@ 92.6 mph www.modularV8.com "CLUTCH KILLER" and also recently known as the DRIVETRAIN KILLER
Posts: 1,732 |
Originally posted by SF-SVT: I was wondering bout the flange too.. Is there supposed to be two or three flanges?? (i lost the parts sheet after i installed the pipe) Cuz i also received another package with the single flange 3 days later. (if it turns out that there is only supposed to be 2 flanges, i can give the extra one i have to some one who needs it.. svt st pete?? or anyone else)
merrick merrick: i would appreciate that! if i don't have it by monday, i'll let you know and reimburse you for shipping - i need it for install that weekend. regarding exhaust leaks: i read in previous posts that the clamps aren't quite sufficient and leak, so many have have it welded on... but i'll let you know - thanks!
Posts: 2,061 |
Originally posted by SVT ST PETE: merrick: i would appreciate that! if i don't have it by monday, i'll let you know and reimburse you for shipping - i need it for install that weekend.
but i'll let you know - thanks!  On the installation instructions the specifically recommend that you use some orange rtv (high temp) to seal those pipes. I'd rather do that then welding, especially on SS. Hey great news.. got the little white box also.
Dave Andrews Black&Tan 2000 SVT 225 of 2150 Bassani.. UNCORKED davelandrews@comcast.net "Nothing is so firmly believed as what we least know." -Montaigne
Posts: 176 |
I got mine on the 18th and was putting it on when I found out that the small pipe that goes to the rear of the motor was not bent right. So I called ShoSHop and I will be getting a new one on Monday
98 SVT Black #3502 BEL_SVT@home.com
Posts: 4,476 |
mine was the same, but the guys at the shop were able to "adjust" accordingly and used their best welder to finish it up right, they said the short pipe down was off by about 5 degrees (pretty slight but noticable)..
