Posts: 84 |
I think that reply just about covers all the bases. I'm sure there will be no disappointments.
1998 MYSTIQUE LS (STOCK. WITH MANY HOPES OF FUTURE MODS)
Posts: 2,061 |
Originally posted by Chris Hightower: The final product will not have amber blinkers. This is due to the extra wiring that needs to be done for that. The stock taillights have wiring for two filaments:
1. Regular running lights/park 2. Blink/Brake/hazard
In order to separate the blink/hazard from the brake, you need to tap into the wires that go to the front lights. The general public will not want to do that. These taillights will have just the red circle that does all the same function as the stock unit. They will fit on ALL years Contour and Mysique. There will be a few different versions of them as well.
The final design is still in the works. They are still getting made, so we really don't need anymore responses. Thanks to all that have so far. Keep an eye on the "Group Buy" section for when they become public. The thread will include ALL the information you will ever want.
Thanks, Umm I'm willing... anyone else??? To get amber turn signals is really the only reason I would do this mod.
Dave Andrews Black&Tan 2000 SVT 225 of 2150 Bassani.. UNCORKED davelandrews@comcast.net "Nothing is so firmly believed as what we least know." -Montaigne
Posts: 778 |
Hey Chris, great job so far, keep us all posted on your progress. I'd be interested in picking some of these up when the time comes...
Posts: 134 |
whuts up everyone. Ive just been sittin back and watchin everyone reply to these, personally I have been waiting for the final pictures to come out, but as far as i can tell, Im interested too. Chris, keep posting pics please  .
N S K Nomi K. 99 red SVT Kenwood CD player Portable DVD kkm intake Dreamcast Interior Neons Underbody Neons
Posts: 3,636 |
I'm with Dave Andrews. The only reason I would consider this is for amber turn indicators. I'm an EE, so I think I could handle the wiring  I'd need to look at it a bit, but I suspect you change the wiring at the brake light switch so the existing wires going to the rear brake/turn filament would only go hot during a turn or emergency flasher. You could then drive the stoplights using the third brake light. I can look at it a bit more if some were interested. I don't know thing one about plastic fabrication, but I could probably figure out the electrics. TB
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Posts: 3,636 |
I just looked at the wiring diagrams for the 99 Contour. The brake lights run through the turn signal module, so it appears you could just cut the wire going to the turn signal module and those wires will only go live when you have turn signals or flashers on. You would have to cut it there, because if you broke the connection at the brake light switch things like your cruise control wouldn't turn off and possible ABS problems as well.
You could then run a new wire from the brake light switch to the back of the car for the dedicated brake light only. Or you might be able to drive this off the third brake light, depending on the current draw. I think I saw LEDs in the sample unit.
It seems from the diagrams the connectors I'd go after are in the steering column, right at the Turn Signal Switch, or there is a junction that is supposed to split the Brake Light "signal" in/near the LH A pillar.
So it really appears to be a simple wiring change. If you've wired speakers, this should be just as easy.
As soon as I can get around to converting the images from the service CD to a jpg, I'll post them here.
Chris, don't give up on the amber turns just yet, the wiring is real simple.
I may run a test using my backup lights as turn signals. Or I could just disconnect the brake light switch and verify the turnsignals still work.
HTH
TB
Administrator
Administrator
Posts: 5,037 |
Tony,
My taillights that I will be red and amber. There might be a run of red/amber tails in the future, but most people are going to want a direct replacement without any other work. That's what we are focusing on.
The single light tails are going to be great. Wait and see.
Posts: 3,636 |
The single light tails are going to be great. Wait and see. [whine] But I want amber turn signals too. Mom, it's not fair, Chris is getting amber turn signals, but I can't get any. Mom!?![/whine] Ok, I feel better now. Anyway, I do hope what I posted will help out. Cheers, TB
Posts: 69 |
"the rats are on the cheetos again" Jet mechanic 98 silver frost SVT DMD K&N FILTER 36,300 MILES PIONEER 6CD CHANGER AND SPEAKERS 2 BAZOOKAS
Posts: 1 |
Sounds good to me, count me in, and keep me posted. That's why I joined this group
