Page 1 of 4 1 2 3 4
Well after working with the Steering and Supsension Group of my company (AAM) I got them to CNC bend me up a couple of 24mm HOLLOW sway bars. Their geometry is basically identical to the stock version , with the exception of the diameter ofcourse.
Anyhow on Saturday morning I installed it in my driveway.
The trickiest bit to the hole install is getting the stock bar out of the car and the new one in due to the gap between the front of the rear subframe and the back of the gas tank. The gap is probably about 15mm, so even getting the stock SVT bar out is hard!
The trick to do it is to support the gas tank with a jack and loosen off the tank straps to allow you slide the gas tank forward to increase the gap.
Once that's done it all easy sailing from there.
The bar fits beautifully in its place. No interference whatsoever, there is plenty of clearance in the vehicle. I reused the stock brackets but used 15/16" poly bushing in place of the junky stock rubber bushings. I also removed the stock tie rods and cut the crappy rubber bushings off the trailing arms and replaced them with Ø1-1/8" X 5/8" polyurethane endlink bushings.
With it all bolted back together, the fit and finish is great. There are ABSOLUTELY NO CLUNKING OR CREAKING noises from the rear end.
And the most important thing....the handling is
INSANE!!!!
Almost all the body roll is gone and understeer has become a thing of the past. The car is very neutral now (feels weird for a FWD!), and throwing her into corners rewards you with a tight line and minimal tire protest. This has to be the
BEST
handling mod, hands down. It really compliments the H&R springs I have on the car. My car handles now, how it should have from the factory by SVT! The only disappointment was that the adjustability I was trying to incorporate is not possible due to the design of the tie rod ends, which basically don't move, so you can't tilt them to access the other hole. Also the subframe is too close to the end of the bar (1" clearance) so the extra length in the arms would cause interference. But with the way the car handles I don't see why you would want to adjust it for more understeer, so it really doesn't matter. It's perfect now!
I need to here from at least 25-30 people who could lay down $110 for each bar. I will also supply you with bushings for both the sway bar and tie rod ends. the stock bracket get reused.
If you are SERIOUSLY interested in getting in on a group buy, let me know buy posting here AND by email, so I can show the finance department here.
For the engineers out there specs are as follows:
Steel: SAE 4140 24mm (15% wall) tube, heat treated.
Coating: E-Coat (hardened powder coat)
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
Administrator
Administrator
sounds like a great rear bar Stazi, i'd just be a little worried about those stock brackets holding up.
I may be interested in one, but my finances are a bit stretched currently.
It's all about balance.
bcphillips@peoplepc.com
I will be supplying the bushings WITH brackets, so if you wanted to weld an extra plate onto the rear subframe you could to incorporate the new brackets.
Regards,
Anastazi
Here is some extra info, which I posted on the NECO forum after someone questioned the validity/performance of a hollow bar in comparison with a solid bar.
OK, seeing as none of you believe me I will give you the engineering math. A hollow bar of x mm in diameter is not necessarily torsionally stiffer than the same bar in solid, BUT the difference is minimal , yet the weight reduction is signifigant.
Any how, the Polar moment of inertia J is directly proportional to the the 4th power of the diameter, and as such the equation for polar moment of inertia of a solid round bar is:
J=(pi*d^4)/32
The same equation for a hollow round bar is:
J={pi*(do^4-di^4)}/32, where do is the outer diameter and di is the inner diameter.
And due to the fact that we use such a high power (4) the removal of the center doesn't really hurt the torsional rigidity, but save a LOT of weight.
Hence for a 18mm SVT rear sway bar the polr moment of inertia is 10305.994mm^4
For the aftermerket 22mm solid it's 22998.029mm^4 (223% stiffer than stock)
And for my 24mm hollow (15% wall) it's 24751.487mm^4 (240% stiffer than stock and 17% stiffer thanthe 22mm bar)
But here are the weights!
Lets compare cross sectional areas; the 18mm bar is 254mm^2, the 22mm bar is 380mm^2 and finally the hollow 24mm bar is 230mm^2. So if all were from the same material the 22mm bar is 50% heavier than the stock SVT bar (18mm) and the 24mm hollow bar is 10%lighter than the stock SVT bar.
So you CAN have you cake and eat it too.
Now.... I don't want to hear anymore BS please, just orders! laugh
email me if you want to order a bar at sarigia@aam.com
Thanks,
Anastazi
Regards,
Anastazi
p.s. shipping is $10 flat rate to the Continental US and Canada.
So $120 will get you the bar shipped to your door with poly bushings (Prothane) for the sway bar and end links AND upgraded brackets to install if you wish to use a weld-on backing plate.
Regards,
Anastazi
Im interested... Ifbuyers are light, I'll even buy the 2nd of two prototypes.
Lee
98 Black SVT
Do you think that this would work well with the stock springs & struts?
"00 SVT Silver Frost
Sho-Shop Y Pipe
Borla Exhaust
KKM
i was wondering if you have pics of the brackets? Or if you sell the brackets separate? Thanks
Merrick
Silver 98.5 SVT
5/19/98, 6023
Brackets and bushings are like these:
And end link bushings will be like these:
Regards,
Anastazi
Anschutz,
The bar will work well with stock suspension, but ofcourse the benifts of the bar are compunded by performance springs and struts.
Regards,
Anastazi
Page 1 of 4 1 2 3 4
Moderated by  1314_dup1
